70 Challenger brakes #2381878
10/04/17 05:50 PM
10/04/17 05:50 PM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Brake question- Driving the Challenger and noticed a front brake dragging. Eased it home and ordered a set of calipers from Napa. Bled it out today and both front brakes are tight. Checked the metering valve and the pin is not moving when the brakes are applied. I can tap it in and it comes out when when brakes are applied but doesn't go back in on its own. Seems like I took it apart and cleaned it when I built the car 15 years ago. Does this sound like a metering block issue or maybe something else? 70 RT with disc brakes.
Re: 70 Challenger brakes [Re: Carsavior] #2381887
10/04/17 06:01 PM
10/04/17 06:01 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Also check to see if the master cylinder rod is adjusted and has about .30 play and is not keeping the brakes on.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 70 Challenger brakes [Re: Carsavior] #2381898
10/04/17 06:14 PM
10/04/17 06:14 PM
Monroe, LA USA
Monroe, LA USA
Car has been built since 2002. Brakes have always worked great. I used a later aluminum master cylinder with stock line routing. 11.75 front discs and Imperial rear discs. This is the first issue it has given me.
Re: 70 Challenger brakes [Re: VCODE] #2381919
10/04/17 06:19 PM
10/04/17 06:19 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Bob
Make that .03" Not .30".
.30 is almost 5/16th of an inch, which is more than 1/4 inch, WAY too much. :-)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 70 Challenger brakes [Re: Carsavior] #2382027
10/04/17 07:26 PM
10/04/17 07:26 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Check the hoses, if they collapse the brakes will drag.
Re: 70 Challenger brakes [Re: 71birdJ68] #2382038
10/04/17 07:58 PM
10/04/17 07:58 PM
Monroe, LA USA
Monroe, LA USA
No hoses. All braided stainless lines
Re: 70 Challenger brakes [Re: amxautox] #2382040
10/04/17 08:05 PM
10/04/17 08:05 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Bob
thanks, turned number around while typing.
Re: 70 Challenger brakes [Re: VCODE] #2382082
10/04/17 10:10 PM
10/04/17 10:10 PM
IN
ahy Offline
ahy  Offline
IN
I have had the "hoses collapsed" front dragging. It is possible with stainless also I think if the liner collapses... but not likely both at once.
I am not an expert on prop valves... but generally seems like they are a potential problem and limited benefit. The fronts usually run fine on a simple "T" and rears, adjustable valve only if needed.
I you bring her home with front brakes tight, try cracking a front bleeder one at a time. Does that loosen one wheel? Or both?
Re: 70 Challenger brakes [Re: Carsavior] #2382132
10/04/17 11:17 PM
10/04/17 11:17 PM
new calipers & it is still dragging? Both sides dragging or just one? You might jack up the front end & hit the brakes to get em dragging then loosen a caliper bleeder to see if it is a psi or a mechanical (caliper) problem tho with both sides acting up at the same time all of a sudden for sure sounds like a psi issue. As said if power then check the pushrod round nub clearance. Post how it turns out. EDIT If power I would remove the 4 MC nuts & space the MC slightly forward from the booster with some washers & see if that resolves it & if so then I would go ahead & seperate the MC from the booster & measure the gap/shorten the rounded pushrod nub to get ~.020" gap.
Re: 70 Challenger brakes [Re: RapidRobert] #2382719
10/05/17 10:38 PM
10/05/17 10:38 PM
Monroe, LA USA
Monroe, LA USA
Loosened master. No change. Holding pressure. Took off flex lines. They're good. Pulled proportioning valve and metering valve. Isn't there a combination valve or something that people use to get rid of the metering Valve? Since I've got these off I'm going to replace them. They're only 48 years old...
Re: 70 Challenger brakes [Re: Carsavior] #2382720
10/05/17 10:41 PM
10/05/17 10:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The combination valve is a combination of proportion and metering in one assembly.
Don't be the exception.
Re: 70 Challenger brakes [Re: Supercuda] #2382766
10/05/17 11:52 PM
10/05/17 11:52 PM
I'm assuming when you crack the "out" line from the prop valve forward to the front calipers that they release?
Re: 70 Challenger brakes [Re: RapidRobert] #2382775
10/06/17 12:12 AM
10/06/17 12:12 AM
Monroe, LA USA
Monroe, LA USA
Is metering valve really necessary? If anybody has a proportioning valve similar to the stock one I can probably reroute the lines to fit. With the 4 wheel discs I'm wondering if i really need a metering valve...
Re: 70 Challenger brakes [Re: Carsavior] #2382821
10/06/17 02:19 AM
10/06/17 02:19 AM
iirc a guy used no valve at all with 4 wheel discs & it was fine. You could get some short lengths of prefabbed 3/16" brake lines & some double female 3/8-24 connectors at your parts house & bypass it & see how it acts. Not exactly the same but I added '76 A (2.75 bore) discs to the front of my 65 dart & kept the OE splitter & no added prop valve and a dual bowl 1&1/8" alum MC & it worked flawless. It would lockup the rears (10x2 or 2&1/4 (whatever the BBP 7&1/4 is) with hard brakeing but no issue. Ceramic pads in the front. No pad wear that I ever noticed. EDIT the connectors are double female IFF inverted flare female (will have a recessed conical seat on each side of the brass connector)
Re: 70 Challenger brakes [Re: RapidRobert] #2383126
10/06/17 08:59 PM
10/06/17 08:59 PM
Monroe, LA USA
Monroe, LA USA
Thanks.
Re: 70 Challenger brakes [Re: Carsavior] #2383146
10/06/17 09:50 PM
10/06/17 09:50 PM
Minn
SportF Offline
SportF  Offline
Minn
What most everybody here is calling a "proportioning" valve is the valve that gives you dual (individual front and back) brakes. Without it, you don't have dual brakes.
Kinda defeats the dual master cylinder install.
