Page 3 of 4 1 2 3 4
Re: Ring Gap [Re: moper] #23797
04/24/06 12:18 PM
04/24/06 12:18 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
In the rings' case, you have a small amount of time to release the pressure bled thru to the second ring. (the piston's upstroke) So you want to make sure there is enough room to get it out.
Just FYI, you have the exhaust stroke, the intake stroke and part of the compression stroke to bleed the pressure off.
Re: Ring Gap [Re: BradH] #23798
04/24/06 12:38 PM
04/24/06 12:38 PM
Las Vegas NV
Las Vegas NV
...pressure builds up and tries to escape not only through the ring end gaps, but past the rings' seating surface...
Isn't this exactly what I've been suggesting / asking???
If the only top ring leakage is at the end gap, then there is no reason for the second ring gap to be any larger than the top ring gap (i.e., if the barn's front door only opens wide enough for one cow to go in, the back door only needs to be wide enough for one cow to go out to keep from having a traffic jam ).
Yes, but you still are not taking into account the HUGE differential pressure differences.
Let's use your Barn analogy and the UFO ship.
Normally, 1 cow goes in, 1 cow gets out.
But, when you have an explosion(we'll use the UFO ship) that shoves 50 cows in through the front door in 10 seconds, and then gives them 30 seconds to get out the back door, well, a few may get out, but many are still inside.
This is what is going on. You have the aid of the combustion explosion to force the pressure into the gap, but, you don't have the aid of a vacuum to empty the gap out in the same amount of time so you get ring flutter and compromised sealing.
Re: Ring Gap [Re: moparmanjames] #23799
04/24/06 01:53 PM
04/24/06 01:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... the UFO ship... shoves 50 cows in through the front door in 10 seconds, and then gives them 30 seconds to get out the back door...
Those darn UFOs are always messing with things...
One extra cow or fifty, the point was if there wasn't any additional pressure getting past the top ring, then there wouldn't be a reason for the second gap to be any bigger than the first. And that wasn't being addressed in the earlier discussions in this thread, only that the 2nd gap needed to be "bigger" and having it the same with both rings wasn't supposed to get the job done.
Re: Ring Gap [Re: BradH] #23800
04/24/06 02:08 PM
04/24/06 02:08 PM
Las Vegas NV
Las Vegas NV
Maybe the answer is to try and not let any cows in the barn at all, a.k.a. gapless top ring.
but Speed pro says that is just a gimmick and doesn't work as well as a larger second gap.
Re: Ring Gap [Re: moparmanjames] #23801
04/24/06 02:12 PM
04/24/06 02:12 PM
BradH Offline
BradH  Offline
At this point I don't have any long-term results for how those work in my Challenger's 452, just the results from two dyno sessions. Once I've got the pig back on the street & track again, perhaps I'll be able to weigh in on how well the gapless top ring works in the real world. But I ain't holding my breath...
Re: Ring Gap [Re: BradH] #23802
04/24/06 06:30 PM
04/24/06 06:30 PM
Anonymous OP
Anonymous OP
Brad, all of your questions and concerns were answered earlier in the thread. the only problem i see is your either reading right past it or choose not to believe it.
why do you think speed pro, JE and many other companies tell you to open the 2nd gap larger than the first?
here's a link to an article about it. http://www.aa1car.com/library/ring_end_gap.htm
or maybe read the ring gap recommendations from someone else here; http://www.jepistons.com/pdf/piston_instrc4032.pdf
I'm sure i could find at least a hundred articles like these and if you search long enough i'm sure you'll find something that will contradict them.
i think your barn door and ufo analogy is funny but far too simplistic. real world trial and error makes me do what i do with regard to ring end gaps. I don't know of any other way to explain it to you.
Re: Ring Gap #23803
04/24/06 11:46 PM
04/24/06 11:46 PM
BradH Offline
BradH  Offline
That's funny... I just re-read the entire thread and, until I started asking questions, NOBODY (including YOU) got into any explanation as to the source of the pressure being from anywhere besides the top ring gap. Until the discussion turned to the issue of pressure getting past the top ring's seal against the cylinder, NOBODY had answered my question as to why the second ring's gap needed to be wider than the top ring's gap in order to successfully bleed off any pressure between the two rings.
So, it's NOT a case of "your<sic> either reading right past it or choose not to believe it.
". Instead, I have no problems questioning why until somebody can actually explain it to me at a level of detail that makes sense... and you didn't.
Re: Ring Gap [Re: BradH] #23804
04/24/06 11:55 PM
04/24/06 11:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How about this mr.hawk
IT WORKS.........and some of the best in the business use the wider second ring gap w/ great results like...MORE H.P. AND TORQUE!!!
Re: Ring Gap [Re: BradH] #23805
04/25/06 12:15 AM
04/25/06 12:15 AM
Anonymous OP
Anonymous OP
oh, okay brad. i get it now. maybe the pressure is coming from the your UFO ufo or the cow farts. who cares. the bottom line is it works. i told you it works, others told you it works, but that's not good enough for you. i posted articles you could read that tels you it's recommended. you could've even done a little research on your own but NOOOOOOOOOOOOOO. none of that is good enough.
what more do you want? it's 12:21 a.m. and it's dark outside. do you need a good explanation as to how that can be also?
at least Don Hines got his question answered.
Re: Ring Gap [Re: BradH] #23806
04/25/06 12:20 AM
04/25/06 12:20 AM
Cab_Burge Online work
Cab_Burge  Online Work
Brad, trust me buddy, it works (larger ring gap on the second ring to allow the top ring to stay against the cylinder wall)
Re: Ring Gap [Re: Cab_Burge] #23807
04/25/06 12:26 AM
04/25/06 12:26 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Unless you are running significant(over 175ish) quantities of nitrous then the rules are reversed. You run a larger gao at the top ring and smaller on the second. Sorry just felt like
Re: Ring Gap [Re: Al_Alguire] #23808
04/25/06 02:12 AM
04/25/06 02:12 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Honestly, I thought it was a no brainer. The larger second ring gap ensures the trapped gasses have a quick exit, and the larger gap allows this. This would essentially be a trade off, a slight loss in ring seal, as opposed to a greater loss due to ring flutter etc.
My
AL...
Re: Ring Gap #23809
04/25/06 10:16 AM
04/25/06 10:16 AM
BradH Offline
BradH  Offline
Guys, it's a mindset thing... what I get paid to do is ask "Why? Why not? Are you sure? How do you know that's the way it should work? Can we do it any differently and improve things?" and then document the piss outta the findings.
Yeah, I've seen lots of people SAY "run wider second gaps because it works", but I haven't seen much / any (or am I overlooking stuff?) documented testing to verify HOW it works, which is what drives my questions. People can draw up one hypothesis after another, but validated test results usually carry a lot more weight for me than opinions.
BTW, nothing that anybody here linked was any more than recommendations as to gap specs, not actual test results.
BTW(2), as I've said many times, I never learn anything the easy way.
BTW(3), 440Jim is supposed to be providing me info re: an article he says includes the type of testing I'm asking about. I'm definitely looking forward to reading it.
Re: Ring Gap [Re: BradH] #23810
04/25/06 10:43 AM
04/25/06 10:43 AM
Las Vegas NV
Las Vegas NV
You are correct on that, I tried finding actual test data but could not.
I know what you mean, I have trouble accepting things that are not backed up with empirical results, but when conditions are such that it is not practical then we theorize and try and make sense of it.
I would also like to see the actual test results to see how big a difference it makes.
Re: Ring Gap [Re: moparmanjames] #23811
04/25/06 10:56 AM
04/25/06 10:56 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
this does not show actual test results but here it is anyhow from sealed power
Notice: Most of the second ring gap recommendations are larger than the top rings. Recent testing has proven that a larger second gap increases the top ring's ability to seal combustion. This larger "escape" path prevents inter-ring pressure from building up and lifting the top ring off the piston allowing combustion to get by. Many engine builders have reported lower blow-by and horsepower gains at the upper RPM ranges with wider second ring gaps. Also, almost every new car made is using this inter-ring pressure reduction method to lower blow-by and emissions and to increase engine output.
Re: Ring Gap [Re: jamesc] #23812
04/25/06 11:25 AM
04/25/06 11:25 AM
Las Vegas NV
Las Vegas NV
Again, not specific test results, but an article written by a Sealed Power application engineer:
Closing the Ring (Information) Gap
Engine Builders Creating Maximum Power
By Managing Ring Gaps Through Proven Technologies
By Scott Gabrielson
Ask any successful engine builder in NHRA or NASCAR competition about his recommended end gaps for the top and second piston rings and you'll probably hear "no comment." And for good reason.
It's impossible to overstate the importance of running with exactly the right end gap if you're hoping to create a perfect combustion seal over the course of a race, be it a quarter- mile pass at an NHRA track or a 500- mile super speedway event.
The fundamental principal behind maximum ring performance and efficiency in a racing engine is sealing all of the compression with the top ring. This fact is born out through the proven pressure dynamics between the top and second rings:
The top ring is sealed against the cylinder wall and the bottom of the ring groove by the pressure differential created during the piston's combustion cycle. As pressure increases above the ring and between the ring's inside diameter and the piston groove, the ring is forced downward and outward, creating a tight seal over a wide range of engine rpm. Even though it is often called a "compression" ring, the second ring in a racing engine should not be counted on to seal combustion gasses, but simply to scrape excess oil from the cylinder walls. In order to utilize the second ring for additional combustion sealing, it is necessary to virtually eliminate the ring's end gap. This, however, is disastrous from a compression standpoint: With a small (or no) second-ring end gap, combustion gases become trapped between the second and top rings. As the piston moves through its power stroke, these gases will lift the top ring off its land, causing extreme loss of seal and promoting ring flutter.
The secret to more power, therefore, lies in keeping the combustion gases above the top ring. And although many engine builders in NHRA and Winston Cup competition won't share their secrets regarding top ring clearances and end gaps, the optimum approach can be found simply by relying on a world-class ring supplier that partners with winning teams.
Fact: There are No Shortcuts
Needless to say, the top ring in a racing engine is required to withstand considerable abuse, in spite of the fact that the rings typically are becoming thinner and lighter to minimize frictional horsepower loss.
The best top-ring technology in today's ultra- high-horsepower engines features a one-piece design utilizing high-strength ductile iron with a plasma-moly facing material. The ductile iron material provides the strength and resistance to detonation required in a racing engine.
The plasma- moly facing has a high melting point to resist scuffing, and a controlled application process that enhances ring lubrication. Some manufacturers use an advanced plasma- moly formulation that also has higher bonding strength to resist flaking and ensure extended face life.
Of course, the optimal top-ring end gap for maximum sealing performance is near ze ro when the engine is at normal operating temperature. The trick comes in determining the best installed ring gap, which, as the engine heats up, will close to provide a complete seal. The correct installed gap is a function of the bore size, piston, ring groove location and operating temperature at the top ring.
Are Gaps Really Necessary?
Is it possible to achieve maximum top-ring sealing with a ring that has zero installed end gap? Not as this technology exists today. One recent zero- gap-type top ring design is comprised of two individual pieces - a high strength ring with a separate steel oil rail-type piece sitting within a counterbore. These pieces are positioned so that their gaps are staggered, thus the claim that they have no installed gap.
This approach offers several concerns: Because the ring is in fact two pieces, both must somehow maintain identical contact with the bore in order to seal properly. If the pieces act independent of one another - which is likely in a high-rpm, high- heat environment - ring face contact would not be consistent and sealing performance would suffer. In addition, if the two pieces perform independently, their respective gaps could become aligned, creating a wide escape path for combustion gases.
In truth, the development of a zero-gap-type top ring begs the question: Why would you then need a second ring that has zero installed gap? The latter technology, which has been available for several years, employs a similar two-piece approach. This configuration has received exhaustive study by many of the best-known engine builders in NHRA and NASCAR competition, virtually all of whom have found that this type of second ring offers no performance advantage. The reason, again, is the potential for trapped gases between the top and second ring to lift the top ring off its land. The development of a top ring with zero installed gap, regardless of its manufacturer's claims, is an acknowledgement that the combustion seal in a racing engine must be at the top ring.
Why do these zero-gap-type rings exist? Because it's a free market, and manufacturers can create and promote their ideas as they wish. The question, however, is if this technology were really valuable, why wouldn't the world's largest ring and engine manufacturers offer it?
The answer is simple: real- world testing by these manufacturers- and racing teams -- shows that this approach is not consistent with good ring dynamics and engine performance. At the very least, you owe it to yourself to ask for certifiable test results from any manufacturer that claims to have a "new" solution to combustion sealing. Ask successful performance engine builders whose rings they use in their racing motors.
What's Right for Your Engines? Our company and others offer detailed ring gap specifications/recommendations for a full range of applications. These recommendations are developed through input from thousands of customers and real-world situations. If you rely on piston rings from a major, global manufacturer that has an extensive presence in NHRA and NASCAR competition, you can be confident that the materials and designs you use represent the best technologies available.
When it comes to choosing the right end gaps for the top and second rings in your engines, use the manufacturer's recommendations as your guide. Again, the key objective is to achieve near- zero top ring end gap under real-world (racing) operating temperatures.
If you're looking for short-cuts for more power through a new ring technology, they don't exist. The best engine builders focus, instead, on perfecting the fundamentals of racing-style rings - choosing the right materials from the best-known manufacturers and adapting these technologies to their engines. You can - and should - do the same.
Scott Gabrielson is Sealed Power piston ring application engineer for Federal-Mogul Corporation. He works with dozens of racing teams in identifying the best ring technologies for championship performance.
Re: Ring Gap [Re: moparmanjames] #23813
04/25/06 11:31 AM
04/25/06 11:31 AM
jamesc Offline
jamesc  Offline
i was going to mention that the second ring is normally referred to as a scraper but figured that would only open up another can of worms.
Re: Ring Gap [Re: moparmanjames] #23814
04/25/06 11:55 AM
04/25/06 11:55 AM
BradH Offline
BradH  Offline
Again, not specific test results, but an article written by a Sealed Power application engineer:...
Thanks. I'd actually found that same article posted elsewhere.
BTW, I'm not saying the wider second gap approach isn't the way to go, since that's certainly my intent when I assemble my next short block. However, I'm still waiting to see some form of test results.
Re: Ring Gap [Re: BradH] #23815
04/25/06 12:25 PM
04/25/06 12:25 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
"Wanted: UFO ship, of suitable size, to force flagulent cows thru small barn roof openning. Must be capable of holding 60 cows, and posess the equipment suitable for the rapid deployment of said bovines."
I'll put that in the "wanted" ads..My barn is small, maybe it will work for me to quantify the results.
JK Brad...Some of the best quotes from leading engineers is .."why?" of course, that also makes them pretty irritating.
Re: Ring Gap [Re: BradH] #23816
04/25/06 01:52 PM
04/25/06 01:52 PM
NC
440Jim Offline
440Jim  Offline
NC
The documented test results were published in Chevy High Performance magazine, with info credit to Sealed Power. Contact the magazine for a back issue of the copyrighted article.
I don't have any more detail.
Page 3 of 4 1 2 3 4
