Rocker arm options for B1 heads. #2381178
10/03/17 11:42 AM
10/03/17 11:42 AM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Just thinking out loud for next build. I plan on somewhere around 600 inches with my Indy block. Probably going with B1MC heads. What would be the difference between shaft mount or paired rockers for the B1 heads. Are there any differences in strength, geometry, alignment, stability? Shaft oiling vs. spray bar oiling concerns?
Re: Rocker arm options for B1 heads. [Re: sgcuda] #2381207
10/03/17 12:21 PM
10/03/17 12:21 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The paired rockers clear a larger spring,are easily removed and installed and the geometry is easy to adjust by shimming the stands. I like to use pushrod oiling with them.
Re: Rocker arm options for B1 heads. [Re: fbs63] #2381213
10/03/17 12:45 PM
10/03/17 12:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I started building my B1MC I used the
paired TD rockers.. the mentioned things
above were some of the reasons but I believe
the mounting bars add to the strength of the
package.. the bars bolt in and as said you
move the height easily.. I had to raise the
height on my W-5s SB .060
wave
Re: Rocker arm options for B1 heads. [Re: sgcuda] #2381230
10/03/17 01:02 PM
10/03/17 01:02 PM
AndyF Offline
AndyF  Offline
Use paired rockers on any serious build. Shaft rocker arms just aren't going to work very well once you start to use serious spring pressure.
Re: Rocker arm options for B1 heads. [Re: sgcuda] #2381271
10/03/17 03:11 PM
10/03/17 03:11 PM
I bought a used pair of B1-MC with the original shaft rockers and titianum valves, the intake valves are a bunch taller than the exhaust and the intake rocker geometry sucks down
I haven't decided yet if I will use Jesels or T&D paired shaft system , but definitely NOT those tsk
Re: Rocker arm options for B1 heads. [Re: sgcuda] #2381414
10/03/17 08:58 PM
10/03/17 08:58 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
T&D paired shaft rockers
Re: Rocker arm options for B1 heads. [Re: sgcuda] #2381649
10/04/17 10:33 AM
10/04/17 10:33 AM
an8sec70cuda Offline
The big B1 motor I worked on had the paired T&D setup. Very nice and never had an issue w/ it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rocker arm options for B1 heads. [Re: sgcuda] #2382278
10/05/17 03:53 AM
10/05/17 03:53 AM
MD
HEMI472 Online content
HEMI472  Online Content
MD
does any one have any T&D common shaft setups ?? I need a shaft ??
Re: Rocker arm options for B1 heads. [Re: HEMI472] #2382724
10/05/17 10:46 PM
10/05/17 10:46 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The paired rockers have a bit more room around them as well. Billet valve covers I've made for the paired stuff doesn't clear the common shaft rockers. Not sure if this is the case for the fabricated valve covers out there
Alan Jones
Re: Rocker arm options for B1 heads. [Re: HEMI472] #2382976
10/06/17 02:43 PM
10/06/17 02:43 PM
Carson City, Nevada
Carson City, Nevada
Just Call T&D they will get you what you need. 1(775)884-2292
If it were me I would send them in and have them checked if you broke or bent a shaft.
Re: Rocker arm options for B1 heads. [Re: sgcuda] #2385678
10/11/17 03:51 PM
10/11/17 03:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
With an MC head the paired rocker is the only way to go IMO. To take advantage of the potential of the cylinder head the spring pressure required will be way happier with the paired rockers and you will gain clearance for bigger(diameter)springs. We do have a common shaft original engine that makes right at 1000hp and so far so good, thankfully you can get really good small diameter springs these days but it down not have a huge spring pressure either 375/1050
