raiator cooling opinions #2378791
09/29/17 12:48 PM
09/29/17 12:48 PM
btomasko Offline OP
btomasko  Offline OP
Which would be the radiator for cooling a 426 hemi? u.s radiator or glen ray the best in your opinions. Thanks
Re: raiator cooling opinions [Re: btomasko] #2378819
09/29/17 01:26 PM
09/29/17 01:26 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
depends if just needs to work or needs to totslly correct
5549 post on old board
Re: raiator cooling opinions [Re: btomasko] #2378852
09/29/17 02:05 PM
09/29/17 02:05 PM
None
71rm23 Offline
71rm23  Offline
None
Glen Ray!!! Give Bob a call
Re: raiator cooling opinions [Re: btomasko] #2379005
09/29/17 07:33 PM
09/29/17 07:33 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Absolutely, give'em a call. Your radiator is only part of your cooling system combination. Don't forget to discuss the rest. Things like your water pump, fan, shroud, thermostats or restrictors. Also, any coolers you may be running and their mounting locations.
My hats off to the guys that get it right the first time but this forum is loaded with posts about cooling issues.
Been there, done that, and had to do it again.
Re: raiator cooling opinions [Re: btomasko] #2379026
09/29/17 07:55 PM
09/29/17 07:55 PM
Indiana
toms Offline
toms  Offline
Indiana
I have a 69 Dart with a 528 hemi pushing over 700 HP. I put a B-Cool radiator with twin fans. No matter what the temp is never gets over 190. The car does not have a hood scope, the motor sits under the stock hood.
