Gas Saver #2378409
09/28/17 06:06 PM
09/28/17 06:06 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Anybody have the gas saver indicator that is working?
Re: Gas Saver [Re: 71birdJ68] #2378589
09/29/17 12:20 AM
09/29/17 12:20 AM
Are you talking about one of the old Motor Minder vacuum gauges?
If so I do have one and it is not for sale or loan.
Re: Gas Saver [Re: 71birdJ68] #2378593
09/29/17 12:27 AM
09/29/17 12:27 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I'm thinking he is referring to an indicator light that was on certain cars of the late seventies. Been a long time since I was behind the wheel of one so equipped. The modern day equivalent, on my 2014 hemi express, is now an ECO light.
Common sense is a flower that does not grow in everybody's garden
Re: Gas Saver [Re: 71birdJ68] #2378605
09/29/17 01:00 AM
09/29/17 01:00 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wasn't that the deal that lit up the turn signal light on top of the left fender when you got happy on the gas pedal?
Re: Gas Saver [Re: stumpy] #2378614
09/29/17 01:10 AM
09/29/17 01:10 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
God, I had so forgotten about that!
Re: Gas Saver [Re: stumpy] #2378621
09/29/17 01:27 AM
09/29/17 01:27 AM
Morristown Tn.
Morristown Tn.
Yes, it lit up the left fender mounted turn signal when vacuum went down. I was looking through my 75 service manual, and came across it. I think my dart might have it, but I'm not sure. Just wondering if anybody had one that actually worked, and what the components looked like.
Re: Gas Saver [Re: 71birdJ68] #2378666
09/29/17 05:06 AM
09/29/17 05:06 AM
Europe
rory73 Offline
rory73  Offline
Europe
My '77 Volaré came with that and it worked fine. Scared me at first because I didn't know what it was, lol! If you google "Fuel Pacer" you'll find more info. It's basically just a vacuum activated switch that turns on the fender lights.
Re: Gas Saver [Re: 71birdJ68] #2378675
09/29/17 08:03 AM
09/29/17 08:03 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I had a 1975 Duster that had it....
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Gas Saver [Re: Dartsport540] #2378689
09/29/17 09:39 AM
09/29/17 09:39 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I plan on using mine someday on my 57 Plymouth.....just have to get through the instructions grin
Re: Gas Saver [Re: 71birdJ68] #2378698
09/29/17 10:08 AM
09/29/17 10:08 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Interesting devices.
Re: Gas Saver [Re: 71birdJ68] #2378764
09/29/17 12:16 PM
09/29/17 12:16 PM
USA
3
360view Offline
360view  Offline
3
USA
The Brake Specific Fuel Consumption,
or BSFC maps (graphs) have long shown that
there is an "island" of good fuel economy
rising out of a "sea" of poorer fuel consumption.
The horizontal ( East West)
direction of a BSFC map
is almost always RPM,
but sometimes is average piston speed ( more "universal" because engines have different crankshaft strokes)
The vertical ( North South)
direction of such a fuel economy map
can be many measurements such as
Torque, manifold vacuum, throttle position,
or the more "universal" BMEP: brake mean effective pressure.
If Chrysler only put a single light out on top the driver's side fender
indicating a level of manifold vacuum,
didn't this only do half the required job?
To be most effective,
there should have been a second light, or second colored light bulb inside the same glass,
to indicate the driver was also inside the correct RPM range,
which is set by selecting the best gear for that road speed.
Ideally inside the vehicle owners manual
there would have been a
big bold colored graph
showing manifold vacuum on the vertical axis and
RPM on the horizontal axis.
Think this would have been too complicated for typical car owners?
Maybe.
But i bet you that if correct understanding of these lights and graph had been an extra credit item on the driver's license exam, many sixteen year olds ( 14 in Mississippi) would have ace'd it.
Today's teenagers do not seem to be highly motivated about driving, much less understanding automobile technology, but spend hundreds of hours honing video game knowledge.
frown
Re: Gas Saver [Re: 71birdJ68] #2378776
09/29/17 12:31 PM
09/29/17 12:31 PM
USA
3
360view Offline
360view  Offline
3
USA
The light(s) out on the fender are a "public display" that other drivers can see.
Hmm,
that is a new angle,
I had not considered.
What would be my reaction if
another driver in the same make and model vehicle passed me on the Interstate
but as he went by i could see two lights on top his fender indicating from both that he was driving inside the "island of best fuel economy"
whereas my lights showed my vehicle was not?
Aero mods, gear ratio changes, engine mods, low rolling resistance tires, could all honestly cause this.
Obviously, it could be dishonestly "hacked"
Re: Gas Saver [Re: 360view] #2378858
09/29/17 02:20 PM
09/29/17 02:20 PM
Morristown Tn.
Morristown Tn.
Actually, I think fender mounted turn signals were for people to lazy to look down at the panel. You do get used to them. But you're right about all of the other stuff. Read what Charles Lindbergh did to save gas for P-38 pilots in the Pacific theater.
Re: Gas Saver [Re: 71birdJ68] #2378938
09/29/17 04:36 PM
09/29/17 04:36 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Good read... Allowed the P38's to accompany the bombers all he way in and out...
Re: Gas Saver [Re: 71birdJ68] #2379274
09/30/17 12:37 PM
09/30/17 12:37 PM
USA
3
360view Offline
360view  Offline
3
USA
I guess today an $20 Arduino, $10 vaccum sensor and some $5 LED lights could create a Gas Saver front fender light display. I am guessing the Arduino can count electronic speedometer pulses and get RPM from fuel injector pulses. Maybe it could also turn on water injection into the throttle body at some vacuum level like an old Spearco unit.
Re: Gas Saver [Re: 71birdJ68] #2380417
10/02/17 03:57 AM
10/02/17 03:57 AM
Castlegar, BC, Canada
That AMC Guy Offline
It's called the "Fuel Pacer" and lots of Mopars had them well into the 80's. I've seen minivans with a green LED labelled "Fuel Pacer" in the fuel gauge.
I had a Valiant Brougham with it. Really neat gadget. Started many conversations especially at night. With the 2-barrel on the engine, that light was on constantly.
For poops and grins, I used a fuel pacer switch in my baby blue 6-cylinder Hornet to illuminate a "Fuel Economy" lens in the gauge cluster.
Kinda hard to see here but it's the yellow lettering in the lower left quadrant of the warning lamps. I got the lens out of a Pacer cluster as some AMC Pacer's had a similar Fuel Pacer setup.
I have one NOS Fuel Pacer switch left. Don't know what I'm going to do with it yet. I had thought of using it to turn on some strip LED's in the cowl induction hood on my Javelin. That way, at night when you get on the go-pedal, the cowl induction will light up orange.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Gas Saver [Re: That AMC Guy] #2380893
10/02/17 10:43 PM
10/02/17 10:43 PM
IN
ahy Offline
ahy  Offline
IN
I think the idea was to keep the little light on as much as possible. Right?
Re: Gas Saver [Re: ahy] #2380909
10/02/17 10:56 PM
10/02/17 10:56 PM
Morristown Tn.
Morristown Tn.
No, to keep the light out.
Re: Gas Saver [Re: 71birdJ68] #2380937
10/02/17 11:17 PM
10/02/17 11:17 PM
Walmart parking lot
yorker Offline
Drugs are bad
yorker  Offline
Drugs are bad
Walmart parking lot
Had one in a 75 Cornet back in 77. You actually had to be pretty tame on the pedal to keep it off. Anyone that new basic engine or motoring techniques would know without the light if they were driving " gas friendly " or not.
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
