Re: engine swap v8 to v6 truck
[Re: gch]
#2378022
09/27/17 11:33 PM
09/27/17 11:33 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
Are you trying to make a slow truck? 3.9's get about the same MPG as a 5.2. Also, it's getting to the point even stock replacement parts for the 3.9 are drying up.
John
[Re: SattyNoCar]
#2378158
09/28/17 09:37 AM
09/28/17 09:37 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Are you trying to make a slow truck? 3.9's get about the same MPG as a 5.2. Also, it's getting to the point even stock replacement parts for the 3.9 are drying up. He wants to go the other way, 3.9L to 5.9L.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: gch]
#2378315
09/28/17 03:20 PM
09/28/17 03:20 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
i swapped the V6 5 speed from in my '88 to the 318 auto from my '87. The drivers side motor mount had to be fabbed, and one of the trans cross member bolt hole didn't line up. And since I was going from a manual to automatic, I swapped the steering columns, which required the dash harness as well since the '88 had the dimmer and wipers on the turn signal switch.
1981 Dodge D150 360 auto
[Re: Soopernaut]
#2378612
09/29/17 01:09 AM
09/29/17 01:09 AM
SattyNoCar
Are you trying to make a slow truck? 3.9's get about the same MPG as a 5.2. Also, it's getting to the point even stock replacement parts for the 3.9 are drying up. He wants to go the other way, 3.9L to 5.9L. I saw the subject line V8 to V6....... I got it now.....
John
[Re: SattyNoCar]
#2379209
09/30/17 10:19 AM
09/30/17 10:19 AM
Posts: 2,262 Groveland, MA
SteveS
Groveland, MA
Are you trying to make a slow truck? 3.9's get about the same MPG as a 5.2. Also, it's getting to the point even stock replacement parts for the 3.9 are drying up. He wants to go the other way, 3.9L to 5.9L. I saw the subject line V8 to V6....... I got it now..... Me, too.
Steve
Someday I'll have another C-body.
