engine swap v8 to v6 truck #2377986
09/27/17 10:10 PM
09/27/17 10:10 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
I can get a very nice 89 short bed truck with a 3.9 manual trans.What would be any hurdles to swapping the 360 out of my 87 long bed automatic truck?
Will the manual trans bolt up?
Any other issues?
Thanks.
Re: engine swap v8 to v6 truck [Re: gch] #2378022
09/27/17 11:33 PM
09/27/17 11:33 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Are you trying to make a slow truck? 3.9's get about the same MPG as a 5.2.
Also, it's getting to the point even stock replacement parts for the 3.9 are drying up.
twocents
John
Re: engine swap v8 to v6 truck [Re: SattyNoCar] #2378158
09/28/17 09:37 AM
09/28/17 09:37 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
twocents
He wants to go the other way, 3.9L to 5.9L.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: engine swap v8 to v6 truck [Re: gch] #2378315
09/28/17 03:20 PM
09/28/17 03:20 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
i swapped the V6 5 speed from in my '88 to the 318 auto from my '87. The drivers side motor mount had to be fabbed, and one of the trans cross member bolt hole didn't line up. And since I was going from a manual to automatic, I swapped the steering columns, which required the dash harness as well since the '88 had the dimmer and wipers on the turn signal switch.
1981 Dodge D150 360 auto
Re: engine swap v8 to v6 truck [Re: gch] #2378610
09/29/17 01:09 AM
09/29/17 01:09 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 3.9 manual trans stuff will bolt up to the 360, but the flywheel won't have the offset balance the 360 requires. You will need a 360 flywheel. All the other manual trans stuff should work. Do you know which manual trans is in the 89 truck?
There may be wiring/computer issues you will have to deal with, an 89 could tbi or carb. Gene
Re: engine swap v8 to v6 truck [Re: Soopernaut] #2378612
09/29/17 01:09 AM
09/29/17 01:09 AM
SattyNoCar Offline
SattyNoCar  Offline
twocents
I saw the subject line V8 to V6.......
I got it now..... blush laugh2
John
Re: engine swap v8 to v6 truck [Re: SattyNoCar] #2379209
09/30/17 10:19 AM
09/30/17 10:19 AM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
twocents
Me, too.
Steve
Someday I'll have another C-body.
