strut rod bushings???????? #2377984
09/27/17 10:07 PM
09/27/17 10:07 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
I got the moog K7026 bushing kit for my 67 B body. Is this correct kit? the bushings are really thick and I can't get the nut started.
Thank you!
Re: strut rod bushings???????? [Re: Blown61] #2378095
09/28/17 01:43 AM
09/28/17 01:43 AM
Missouri
Big_E Offline
Big_E  Offline
Missouri
Guess I've been out of it too long. This number says it's a new improved design. Suppose to fit your car. Maybe some else has more info for you. I use the K7016A.
Re: strut rod bushings???????? [Re: Big_E] #2378113
09/28/17 02:11 AM
09/28/17 02:11 AM
if that is a protrusion on the middle on the one on the left you might need to trim it back. You do need enough material left for the bushing to do its job so I am just brainstorming on that. Also someone mentioned once about reverseing the big metal washer.
Re: strut rod bushings???????? [Re: RapidRobert] #2378330
09/28/17 03:33 PM
09/28/17 03:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i think that was the A-body guy who putting them on the wrong way out...
