Re: cam berring replacement?
[Re: scratchnfotraction]
#237726
02/27/09 11:31 AM
02/27/09 11:31 AM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
I bit the bullet and just bought the tool.
It will likely get used quite a bit over the span of my life so it seemed like a good purchase.
That and I agree, I do not know how you will get it in there without it....
ROB
1989 Dodge Cummins & 1989 Dodge W-250
[Re: JohnRR]
#237731
02/27/09 02:54 PM
02/27/09 02:54 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
Do a search for "lisle 18000" on the Google and check pricing. I was looking a few weeks ago and found a place that had it for $111.00 vs nearly $200. This is the same model I rented to install my bearings, it works fantastic. It pays to shop around. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: phantomx]
#237732
02/27/09 04:17 PM
02/27/09 04:17 PM
RapidRobert
It's a bit pricey & you might not use it too much but it's a must have when you R&R those bearings & maybe your parts house rents one which would be the better way to go money wise or if you buy one rent it out to your buddies when their turn comes.
