Re: Turbo problem?
[Re: cudaman1969]
#2376406
09/25/17 01:00 PM
09/25/17 01:00 PM
Guitar Jones
What exactly does a new ac mean?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Turbo problem?
[Re: cudaman1969]
#2376452
09/25/17 02:09 PM
09/25/17 02:09 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
what type of intake charge pressures are you seeing (boost PSI)?
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
Re: Turbo problem?
[Re: cudaman1969]
#2376939
09/26/17 02:27 AM
09/26/17 02:27 AM
Posts: 614 Id
mopeman
Id
Pull the intake hose off and give the shaft a wiggle, that will tell you if the bearings are going on it. If it has excessive play, you will need to rebuild it, its a pretty easy and you can a Holset rebuild kit from NAPA for about $80 bucks.
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Turbo problem?
[Re: J_BODY]
#2377043
09/26/17 11:44 AM
09/26/17 11:44 AM
Posts: 8,248 fredericksburg,va
cudaman1969
fredericksburg,va
I saved a guy quite a bit of coin by NOT following the above advise. He actually brought me a turbo to install and told the writer he needed it. As I was beginning to take things apart I'd grabbed the front shaft and gave it a wiggle. Nothing out of the ordinary so I stopped there and called him.... that was why he was replacing it. Thought the "loose" shaft was a sign of it failing. There is "good" loose, and obviously "bad" loose on the shaft of these things.
Sometimes a "whine" or "squeal" noise can be boost escaping under load. Easy to give all the boot clamps a little snug on the air charge system. You can even make a tool to fit the front of the turbo and air psi test it yourself (we have a nice tool at the dealer to do this). Of course it's hard to diag not being "one on one" with the truck, but I've also heard more turbo noise when there is an open element or even K&N style filter in place.
fwiw I can probably count on one hand the amount of turbos that I've replaced for "noise" in the 20 years of doing this. Mine has no play at all but with the hoses off it still whines. What about the waste gate and that other electrical sencer, could they be causing the noise or making the turbo work too hard? For 100,000 miles it never made this noise until I removed the pipe to get yo the ac compressor. My first thought was I had broken or got a hole in the pipe rubbers. What about the filter (too much restriction?)
Re: Turbo problem?
[Re: cudaman1969]
#2377291
09/26/17 07:20 PM
09/26/17 07:20 PM
Posts: 3,051 N.W. Florida
Fat_Mike
N.W. Florida
Almost ashamed to tell this but... I thought the clamps were tight..... Anyone that occasionally turns a wrench and says they never missed anything is a liar. Glad you got it figured out!
