74 Charger Ignition Switch - Column Shift
#2376644
09/25/17 06:44 PM
09/25/17 06:44 PM
Posts: 673 Kennewick, Wa.
71vert340
Kennewick, Wa.
I found a hot spot on the blue wire on the ignition switch plug. There was a cut on the blue wire exposing the copper. I want to either repair the switch pigtail and plug, or replace the switch. How do I get the old ignition switch out of the column without removing the column from the car? I've disconnected the steering coupler from steering box, and slid it off splines after cleaning and marking position. It seems the column shift is preventing me from sliding the shaft up to remove the switch. Do I need to disconnect the column shift linkage? Is there a way to remove the pin contacts from the plug, put heat shrink on the blue wire, and put on an unburned plug or should I just bypass the blue wire around the plug? Suggestions? I'll include a couple of photos. Thanks for help. It's been ages since I disassembled a column shift. Terry
Re: 74 Charger Ignition Switch - Column Shift
[Re: 71vert340]
#2378432
09/28/17 06:59 PM
09/28/17 06:59 PM
Posts: 1,822 Colorado
denfireguy
Colorado
You do not have to remove the steering shaft. You have to remove the cover off the bottom of the column. You may have to remove the support under the column. Biggest issue is removing the ignition lock plate. There was a tool for it back in the day. The new switch comes with the wiring and connector attached. After removing the lock plate, remove the lock cylinder. The cylinder should be in lock position, look for a small slot on the interior end of the cylinder housing and push a small screwdriver in there and pull the lock cylinder out. Three screws hold the switch in place. Feeding the wires down the tube is not easy but doable with the column in place. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 71vert340]
#2386737
10/13/17 11:05 AM
10/13/17 11:05 AM
Posts: 21,403 It's a dry heat
gtx6970
It's a dry heat
I found a hot spot on the blue wire on the ignition switch plug. There was a cut on the blue wire exposing the copper. I want to either repair the switch pigtail and plug, or replace the switch. How do I get the old ignition switch out of the column without removing the column from the car? I've disconnected the steering coupler from steering box, and slid it off splines after cleaning and marking position. It seems the column shift is preventing me from sliding the shaft up to remove the switch. Do I need to disconnect the column shift linkage? Is there a way to remove the pin contacts from the plug, put heat shrink on the blue wire, and put on an unburned plug or should I just bypass the blue wire around the plug? Suggestions? I'll include a couple of photos. Thanks for help. It's been ages since I disassembled a column shift. Terry If you look close there is a thin sheet metal cover on top of this plate. take a small flat blade screwdriver and slide said cover up. to expose a round spring pin. Just drive the pin out and the lock plate lifts right off the shaft
