When you paint your engine, #2376443
09/25/17 01:50 PM
09/25/17 01:50 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
do you paint everything (with the exception of aluminum parts like heads, intake) the same color or do you ever paint bolt on parts like the oil pan, timing cover, oil pump a different color? I'm getting ready to paint and was going to paint everything the same color but I started thinking it might look better to have a little contrast by painting some of these parts a different color or perhaps just a different shade of the color that I am painting the block.
Re: When you paint your engine, [Re: 440mopar] #2376449
09/25/17 02:07 PM
09/25/17 02:07 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I prefer to paint everything the same including heads and intake, but them my favorite are modified engines that could pass for stock or basically stock appearing to the uneducated casual observer. Unpainted aluminum quickly gets dull and the grease soaks into the casting pores so IMO aluminum should at least be painted cast aluminum color. But if you're going for more of a race look and you're not trying to pass for stock, then by all means shake it up a bit!
Re: When you paint your engine, [Re: 440mopar] #2376450
09/25/17 02:08 PM
09/25/17 02:08 PM
everything the same color with the possible (maybe maybe not) exception of the valve covers being a different (appropriate) color.
Re: When you paint your engine, [Re: 440mopar] #2376453
09/25/17 02:09 PM
09/25/17 02:09 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
According to what look you want. If you want a stock look, then paint everything like the factory did, but if a modified look is your thing the don't paint the aftermarket parts. I have a full aluminum engine, but I wanted it to look stock, so I painted everything.
Re: When you paint your engine, [Re: 440mopar] #2376456
09/25/17 02:16 PM
09/25/17 02:16 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
engine blue,
intake blue if iron, if al. I leave it nonpainted
water pump and such blue
all brackets black
valve covers stock = blue, if cast al. leave alone
if a year of car/engine is suppose to be orange, I paint it blue. grin orange isn't in my vocabulary. whistling
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: When you paint your engine, [Re: amxautox] #2376467
09/25/17 02:27 PM
09/25/17 02:27 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I'm not going for a stock look. I am painting the block a dark cast iron color. I was thinking maybe it would look good to paint the oil pan, timing cover and oil pump in cast aluminum but then again, maybe not.
Re: When you paint your engine, [Re: 440mopar] #2376476
09/25/17 02:43 PM
09/25/17 02:43 PM
Your the builder, it is your deal so do what makes YOU happy up twocents
I've painted them without all the lower end fasteners(oil pan, timing cover) and painted them silver for contrast per a customers request up work It was noticeable work
Re: When you paint your engine, [Re: Cab_Burge] #2376483
09/25/17 02:50 PM
09/25/17 02:50 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Do you think it looked bad?
Re: When you paint your engine, [Re: 440mopar] #2376491
09/25/17 02:58 PM
09/25/17 02:58 PM
this may be a stretch but after seeing some of the offbeat color schemes on car bodies I was thinking of getting a 1/24? plastic model kit car & painting it various combos to see what scheme/color grabs me & I suppose a person could do that with a model engine also (I'd want a bigger model eng). As you know when the time comes triple clean all surfaces & I do a final cleaning by drowning the surface with brake kleen, gets onto the rough surface pores on blocks/intakes etc.
Re: When you paint your engine, [Re: RapidRobert] #2376494
09/25/17 03:02 PM
09/25/17 03:02 PM
amxautox Offline
amxautox  Offline
I did that with a picture of my AMX. Got the little touch up paint vials and painted the picture and finaly got the colors I wanted. Had to get the angles correct as well as the shade of the colors.
Tom
author unknown
Re: When you paint your engine, [Re: amxautox] #2376533
09/25/17 03:48 PM
09/25/17 03:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I usually paint the long block a single color.
Then use black for covers and brackets.
I have used stainless hardware for pans and covers for a little sparkle.
I try to keep it kind of plain looking & stay away from the chrome dress up stuff.
I have mechanical Aptitude.
I can screw up anything.
Re: When you paint your engine, [Re: 440mopar] #2376536
09/25/17 03:54 PM
09/25/17 03:54 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought it would be cool once to paint everything separate and use non stock bolts on the oil pan and valve covers. The oil pan got button headed allen bolts. IT looked cool but later with the engine in the car, access to the forward oil pan bolts was a pisser. I went back to standard 6 point bolts after that.
Re: When you paint your engine, [Re: 440mopar] #2376638
09/25/17 06:36 PM
09/25/17 06:36 PM
No.
He liked it a lot, it was different. Not bad looking and not impressive by my standards shruggy
I'm a racer, not a show car guy so keep that in mind up
Performance is much more important to me than looks, just like my women devil whistling grin
Re: When you paint your engine, [Re: Cab_Burge] #2376735
09/25/17 09:13 PM
09/25/17 09:13 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
This. And I get what your thinking about. A little contrast can be cool IMO. My current stuff is painted similar to factory, just like most folks do......kinda boring.
Re: When you paint your engine, [Re: BSB67] #2376829
09/25/17 10:54 PM
09/25/17 10:54 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
Only one color to paint a 440 and that's orange in my book. Here's my motor as of now.
