Gauges Failing #2376074
09/24/17 09:41 PM
09/24/17 09:41 PM
nowhere
Sponge Offline OP
Sponge  Offline OP
nowhere
Hi All!
I'm having some issues with the Temp and Gas Gauge on my 1968 Plymouth Valiant. Some time ago the Temp gauge quit, I didn't worry about it becauce I have a second Autometer gauge, and now the gas gauge has failed. Both gauges have failed to the low side.
I tested the wires to both sending units. With a test light and the key on the light blinks. I then grounded both wires and the gauges begin to climb. I changed the temp sending unit but nothing changed.
It appears the voltage at the sending unit is only about 2-3 volts. Is it possible for the IVR to fail this way or could I have a different issue?
Re: Gauges Failing [Re: Sponge] #2376105
09/24/17 10:38 PM
09/24/17 10:38 PM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Check the pass thru connector at the fire wall for corrosion and or poor connection.
Re: Gauges Failing [Re: Sponge] #2376144
09/24/17 11:23 PM
09/24/17 11:23 PM
nowhere
Sponge Offline OP
Sponge  Offline OP
nowhere
It looks good to me. I pulled the middle plug off with the purple wire for the temp sending unit. It was clean and tight. The fuel wiring runs thru the kick panel and to the trunk.
Re: Gauges Failing [Re: Sponge] #2376179
09/25/17 12:48 AM
09/25/17 12:48 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
make sure all the instrument cluster screws are tight. I don't know if it will make a difference but some dash issues are caused by a bad ground.
Re: Gauges Failing [Re: Sponge] #2376189
09/25/17 01:10 AM
09/25/17 01:10 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Those are probably the only two gauges on your dash circuit the limiter controls, and you are having trouble with both. I'm suspect of the limiter. However, when you grounded the wires, did the gauges peg to the end? If they did, the limiter is still good, and putting out five volts as it should. The sending units are actually variable grounds, eliminating them by grounding the wire lets five volts through the gauge, pushing each to max reading. If the limiter fails, gauges either won't read, or be on the low side.
Re: Gauges Failing [Re: Sponge] #2376190
09/25/17 01:10 AM
09/25/17 01:10 AM
Your on the correct track on suspecting the instrument voltage regulator as potentially the cause of the low readings thumbs
It is over 45 yrs old and who knows how many hours of use work
I would buy a new one, NAPA and I think Rock Auto both offer them scope
I don't remember what the correct voltage is suppose to be going to those two instruments but I think it is higher, closer to 8 volts pulsing maybe confused
Hopefully someone else with a 1968 FSM will chime in and get you the straight scoop on this luck
Re: Gauges Failing [Re: Bull1tt] #2376206
09/25/17 01:38 AM
09/25/17 01:38 AM
nowhere
Sponge Offline OP
Sponge  Offline OP
nowhere
I just double checked the temp gauge and it quickly climbs right to the end when the wire is grounded and the key is turned on.
Re: Gauges Failing [Re: Bull1tt] #2376564
09/25/17 04:35 PM
09/25/17 04:35 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sorry to butt in but my van has this symptom.
What does this limiter look like and where might I find it?
I have mechanical Aptitude.
I can screw up anything.
Re: Gauges Failing [Re: bboogieart] #2376590
09/25/17 05:06 PM
09/25/17 05:06 PM
type in mopar voltage limiter on Ebay. it plugs in on the back of the dash.
Re: Gauges Failing [Re: RapidRobert] #2376601
09/25/17 05:25 PM
09/25/17 05:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanks R.R.
"back o dash"?
I am assuming you mean the gauge panel?
Re: Gauges Failing [Re: Sponge] #2376611
09/25/17 05:45 PM
09/25/17 05:45 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If the gauges top out when you ground the sender wire the problem is the sender. The gauges won't move if it's the gauge or the VR and yes the VR plugs into the back of the gauge panel. Napa or Rock Auto.
Re: Gauges Failing [Re: Dave Hall] #2376625
09/25/17 06:07 PM
09/25/17 06:07 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
On the gauge regulator, it can fail two ways. If it fails open, the gauges won't work, and if it fails closed, then the gauges will be burned up, as in dead, and ruined. I would not put another mechanical regulator back in the car either, especially because it probably would be made in china. There is a solid state regulator made by Real Time Engineering that if it falls it does it so the gauges won't get burned up.
Re: Gauges Failing [Re: Dave Hall] #2376670
09/25/17 07:27 PM
09/25/17 07:27 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By Dave Hall
If the gauges top out when you ground the sender wire the problem is the sender. VR plugs into the back of the gauge panel. Napa or Rock Auto.
OK so the gas gauge is at half mast when the tank is full.
That is the sender in the tank.
I'll try grounding the sender and see what it does.
At least I've identified the resister. grin
Thanks. up
Re: Gauges Failing [Re: 71birdJ68] #2376676
09/25/17 07:33 PM
09/25/17 07:33 PM
yes definitely get an electronic version & what Dave said, I was thinking the same thing that if you ground it & it pegs that it is the sender (or sender outer body not grounded) at least on the gas tank sending unit tho you would think the temp sender operates the same way but he did mention a very low voltage reading but maybe the pulsating method it gets 5 volts is misleading on some meters. jumpering the sender body (not the threaded stud) on it to ground would answer that (or ohming it) but he said he replaced the sender with no change. keep us posted.
Re: Gauges Failing [Re: Sponge] #2378620
09/29/17 01:25 AM
09/29/17 01:25 AM
nowhere
Sponge Offline OP
Sponge  Offline OP
nowhere
Went out for a good rip tonight and got the car temp up to 200F according to the autometer gauge.The factory temp gauge moved from well below the "C" to the first mark. I'm kind of wondering if I got a temp sensor with the wrong ohm range or maybe a dud? Its aa BWD Automotive Part #WT127.
Re: Gauges Failing [Re: Sponge] #2378623
09/29/17 01:30 AM
09/29/17 01:30 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Now a days, you can't buy a sending unit that matches your gauge like back in the old days. We're stuck with what we get.
Re: Gauges Failing [Re: 71birdJ68] #2378971
09/29/17 05:47 PM
09/29/17 05:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By 71birdJ68
Now a days, you pay first world prices for third world junk
Fixed that for you
Don't be the exception.
Re: Gauges Failing [Re: Supercuda] #2378973
09/29/17 05:53 PM
09/29/17 05:53 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, and they won't let me call this junk what it really is.
