69 RR air grabber ??? #2375966
09/24/17 04:06 PM
09/24/17 04:06 PM
K
KOS Offline OP
KOS  Offline OP
K
on a 69runner with non air grabber hood with the std grilled inserts can I unbolt them and put the screened air grabber units in??
Re: 69 RR air grabber ??? [Re: KOS] #2375967
09/24/17 04:08 PM
09/24/17 04:08 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Why not? You need the whole under hood arrangement to make it work though...
Re: 69 RR air grabber ??? [Re: KOS] #2375977
09/24/17 04:27 PM
09/24/17 04:27 PM
K
KOS Offline OP
KOS  Offline OP
K
yes I know but at least it will release some of the heat from under the hood.....and I like the look of em
Re: 69 RR air grabber ??? [Re: KOS] #2375981
09/24/17 04:37 PM
09/24/17 04:37 PM
CA
crackedback Offline
crackedback  Offline
CA
That's the difference in the factory parts, screens vs plates
Re: 69 RR air grabber ??? [Re: KOS] #2376077
09/24/17 09:45 PM
09/24/17 09:45 PM
cbusters Offline
cbusters  Offline
There are a lot of little parts to do the changeover. The little "L" brackets are a different length that hold the long bars under the screen. Some of the original ones sagged in spots and rattled on bumpy roads because of the wrong sizes. You may be able to rebend or modify them to work and seat on the bar. The screen and bar is thicker than the aluminum insert but I have seen a few that have the brackets just holding the screens with the bar flopping around.
FYI some cars came with double stacked screens in one louver because the long bars weren't there. A couple of the cars I owned were that way, and all the cars I found like that were doubled on the same side. Don't remember which side, but we could come out of a wrecking yard with three screens off of a single car. This was a RoadRunner quirk from the day.
Re: 69 RR air grabber ??? [Re: KOS] #2376130
09/24/17 11:06 PM
09/24/17 11:06 PM
K
KOS Offline OP
KOS  Offline OP
K
looks like they sell screen kits....pretty sure comes with the L brackets and specific long bars....I will makes some ph calls tm to confirm....thx guys
Re: 69 RR air grabber ??? [Re: KOS] #2376155
09/24/17 11:56 PM
09/24/17 11:56 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Do it! Way cooler than the ribbed block offs and most modern hood scoops are called air extractors anyway. A little water won't hurt anything if you get caught driving in the rain.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
