Re: 1969 small block cast waterpump bolt lenghts
[Re: Dart6pak]
#2376032
09/24/17 07:40 PM
09/24/17 07:40 PM
RapidRobert
I dont have a pump in front of me but what I would do is stick some bolts into it on your bench with some lock washers & you want (iirc) 1&1/4 times or a slight bit more than the bolt shank dia, that length of threads to engage into the block. add in the timing cover thickness & its (2) gaskets
[Re: Pacnorthcuda]
#2376044
09/24/17 08:22 PM
09/24/17 08:22 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I always run a bolt in all the holes till it lightly bottoms out then measure for the proper length. You DON'T want a bolt to bottom out in the block on the actual install! Yup, a bolt too long WILL break the cylinder wall, it's been done.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
