Re: A518 overdrive swap into a 68 D200
[Re: Hemi_Joel]
#2375249
09/22/17 11:08 PM
09/22/17 11:08 PM
RapidRobert
Happy birthday young man. I have no exp with that but I have a 65 D100 that a big block/new process granny 4 sp is going into. there's a lot of room there. EDIT just me I would Keep It Simple Sam & swap a 360 & some taller gears in there (& maybe a 904).
[Re: Hemi_Joel]
#2375278
09/23/17 12:19 AM
09/23/17 12:19 AM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
Thanks! The motor in this truck is so solid, I figured I should keep it.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2375496
09/23/17 02:47 PM
09/23/17 02:47 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Does any one have some advice on this swap?
Thanks, Joel Yep. If you want to "wake up" the 318 don't use the A518. A500, 42rh or 44rh: 904-based overdrives that don't suck as much power as the 727-based Turds. Torqueflites
Mo' Farts
Moderated by "tbagger".
[Re: Hemi_Joel]
#2375561
09/23/17 05:09 PM
09/23/17 05:09 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Is that an easy bolt in? Is it strong enough for a truck, and trailer towing? Which one? Since both have only ever been available in trucks, that probably have towed a few things too, I'd say yes. But there are updates that ought to be done. Easy bolt in? Define easy. With zero issues what so ever? No. major hack? No. Driveshaft will likely be too long. Cooling lines are larger. You need to control the lock up and OD. Stock shifter will work.
[Re: Hemi_Joel]
#2375630
09/23/17 07:53 PM
09/23/17 07:53 PM
Posts: 5,857 ohio
ruderunner
ohio
The A500 was pretty much just used in commuter vehicle. The A518 was used in real trucks.
As for od control, yes the easy way is a switch for od. But it can be made"automatic" with pressure switches.
Angry white pureblood male
[Re: Hemi_Joel]
#2375680
09/23/17 09:32 PM
09/23/17 09:32 PM
Posts: 6,003 Salem
Grizzly
Salem
Is that an easy bolt in? Is it strong enough for a truck, and trailer towing? Should bolt right up no problem. There's been plenty of Dakotas and 1st Gen 150's that ran that transmission so, you'd have to look at the tow ratings on them and see if it matches your needs. These Guys know their 904's and 44rh's: SMR Overdrive Link
Mo' Farts
[Re: Grizzly]
#2376008
09/24/17 06:01 PM
09/24/17 06:01 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
904-based overdrives that don't suck as much power as the 727-based Turds. Nice sentiment for the racing forums but hardly germane for a hauling truck.
[Re: Hemi_Joel]
#2376017
09/24/17 06:50 PM
09/24/17 06:50 PM
Hemi_Joel
Minnesota
THere's a few junk 93 - 95 pickups and vans on craigslist around here.
[Re: Hemi_Joel]
#2376021
09/24/17 06:55 PM
09/24/17 06:55 PM
Supercuda
About to go away
About to go away
up yours
do not get an electronically controlled one.
[Re: Hemi_Joel]
#2376160
09/25/17 12:05 AM
09/25/17 12:05 AM
Posts: 4,432 Michigan
MarkZ
Worthy
Worthy
Nobody has asked what kind of budget is available for this. I'm sure SMR is great, but if their price for a complete transmission is anything like what they want for one of their B/RB to 518 adapters your wallet better be pretty heavy.
If you look around you can find a decent 518 with a converter relatively cheap. I put $1500 in mine and to put it behind a warmed over 360. I picked up the trans off of Craigslist for $300, spent $600 on it at the shop having it gone through, $100 in a B&M flex plate and another $500 in a Turbo Action converter. The shop even said it was a factory reman unit with few miles.
The above was seven years ago. This past Spring I lopped the bell of and used an Ultra-Bell to put it behind a 512ci big block. Still going strong.
If I were putting it something like your truck it could probably be done for under $500.
[Re: Hemi_Joel]
#2376169
09/25/17 12:24 AM
09/25/17 12:24 AM
Hemi_Joel
Minnesota
THis is just a stock daily driver type of truck. I was thinking $200 - $300 total budget. BUy a beater/junker for $300ish, yank the trans, sell some parts and the hulk to get most of my $ back, put a kit in it and bolt it in.
I'm new to small blocks and automatics.
[Re: Hemi_Joel]
#2376171
09/25/17 12:41 AM
09/25/17 12:41 AM
Supercuda
About to go away
About to go away
up yours
Yeah, don't fall into the "somebody elses money" game many on Moparts like to play. Your plan will work, though I might give thought to having the trans gone thru if funds allow.
[Re: John_Kunkel]
#2376181
09/25/17 12:49 AM
09/25/17 12:49 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
904-based overdrives that don't suck as much power as the 727-based Turds. Nice sentiment for the racing forums but hardly germane for a hauling truck. I will try to answer this in not such a negative way but I agree with Grizzly. I did the 518 swap from a 904, for the overdrive. This was on a 14 sec 5.9L Magnum in a 4000lbs 87 Ram. The original 904 with it's deep 1st and good efficiency seemed run good w 2.76's. No official numbers with this combo since the trans failed in a few weeks. Swapped to a fresh hydraulic 518 with lockup and 3.55's. Truck had a taller 1st so a swap to 3.55 was absolutely necessary. Mileage seemed the same, high teens and the power was 15.0 @ 90. The 518 eventually lost overdrive but I continued to drive it for a year. Without the overdrive my highway cruising speed changed from 120km/hr to 100km/hr which even without the OD, the lower speed made my mileage calculations spit out the same high teen numbers. Up to this point, I still liked the 518 but a switch to a NV3500 5 speed manual transmission made me realize Grizzly is correct. The 3500 does not have good ratios for racing but the truck went 14.7 at 93mph. To me this is HUGE. The mileage also increased to low 20's, again huge. Those are solid numbers for you guys to soak in but some things can not be put in numbers like a bridge near my house. I had to switch the lock up OFF and 4rth gear OFF to comfortably climb it with the 518. Even though the NV3500 had a similar 5th gear, I could easily climb it in 5th. Same for towing a car. I would try to tow in 4rth with the 518 but it struggled so often I'd let her rev out and just tow in 3rd but the NV3500 had no problems towing in 5th gear.
