Re: Rear end rotation
[Re: 70dusterjohn]
#2375517
09/23/17 03:12 PM
09/23/17 03:12 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
In the future have the camera person stand 90 degrees to the car on the starting line so we can see the initial car movement better Two things cause misfire at the higher RPM, lack of fuel or igintion Lack of fuel doesn't occur in first and second gear, normally it starts in high gear in the upper RPM in 1/4 mile If your using a power adder you might want to close up the spark plug gap .005 or so IHTHs
[Re: 70dusterjohn]
#2376279
09/25/17 10:17 AM
09/25/17 10:17 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Lookin good to me. Keep tightening up the shocks...more the better. FWIW...Saturday can be a slow day on here. Just seeing when you posted this and didn't get much response. A lot of folks don't get on here much over the weekend...I know I don't.
