5/8 Wheel Studs can stock wheels be used? #2374818
09/21/17 11:48 PM
09/21/17 11:48 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I am exploring options on my Ebody...Can stock ralley wheels be drilled out to use 5/8th studs? What lug nuts would you use?
Re: 5/8 Wheel Studs can stock wheels be used? [Re: Dragula] #2374823
09/21/17 11:51 PM
09/21/17 11:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would say not as you will be drilling out the seat the lug nut butts up into.
Don't be the exception.
Re: 5/8 Wheel Studs can stock wheels be used? [Re: Dragula] #2374841
09/22/17 12:39 AM
09/22/17 12:39 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've done this before on aftermarket/OEM rims, however not to Rallye rims though. but it's doable IMHO, you'll need a 60 degree countersink to put the seat back in the hole after you drill the lug hole out .625
Chrome lug nuts are available from Gorilla lug nuts in 5/8-18 right or lefthand thread if so desired
Your only issue might be the center cap clearing the hex shank of the 5/8 lug as they are BIG.... but that can easily be rectified as the cap is thin in that area and potmetal
Re: 5/8 Wheel Studs can stock wheels be used? [Re: Dragula] #2374862
09/22/17 01:32 AM
09/22/17 01:32 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I wouldn't do it with stock factory wheels unless you have wheels originally intended to be used with the 5/8" studs.
Most factory wheels have a raised area around the stud hole that the lug nut tapper sits against. If you drill out the 1/2" stud hole to a 5/8" stud hole, you will be removing most of that raised area. Even if you countersink a new tapper onto the wheel, you will still only be relying on the wheel thickness to seat the lug against instead of the original raised area with the lug tapper. I don't believe the lugs will have enough wheel thickness to bite against without first bottoming onto on the stud threads or the stud shank. The lug nuts may feel tight, and may even torque properly, but they may not have enough contact with the wheel to hold it firmly.
Related story. Years ago we were running in a hobby class at our local oval track. Most of the guys were running the standard 1/2" factory studs with few issues. Some of the late model guys insisted we needed to have 5/8" studs, so we had to comply. Most of us drilled the 1/2" stuff out to install the 5/8" stuff. For the next few weeks our class had a huge issue with loosing tires during the races. The fix was it buy wheels made to accommodate the 5/8" studs, then the problem went away. Gene
Re: 5/8 Wheel Studs can stock wheels be used? [Re: Dragula] #2374900
09/22/17 06:31 AM
09/22/17 06:31 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
dizduster had a thread in the Race section a while back about doing it on his car.
I found it and bumped it up for ya.
