EZ EFI No Start condition/ COMM ERROR #2374071
09/20/17 07:53 PM
09/20/17 07:53 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Well my EZ EFI finally crapped out, anybody familiar with this setup?
I have a no start condition and the computer reads "COMM ERROR"
The tech assistance on their site seems non existent
I sent an e mail and I'm waiting to hear from them.
Re: EZ EFI No Start condition/ COMM ERROR [Re: RV2] #2374073
09/20/17 07:56 PM
09/20/17 07:56 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Re: EZ EFI No Start condition/ COMM ERROR [Re: RV2] #2374172
09/20/17 10:24 PM
09/20/17 10:24 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Gawd I had one, it seems so long ago...I had some initial troubles with mine as the wiring in a 40 Mopar still sucks plus the added 40 years of abuse.
Generally, if I remember, I had to run dedicated wires for the direct connection for power and ground. Everything in the vehicle is useless. Also had a lot of trouble finding a good keyed 12v wire.....An MSD system can muddy up the signal as well....keep it away from that.
Re: EZ EFI No Start condition/ COMM ERROR [Re: RV2] #2374729
09/21/17 09:01 PM
09/21/17 09:01 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Actually this is the first dual quad setup from them, my car was featured in Mopar Muscle for the install.
I haven't had any problems till now.
Re: EZ EFI No Start condition/ COMM ERROR [Re: RV2] #2374775
09/21/17 10:55 PM
09/21/17 10:55 PM
Dragula Offline
Dragula  Offline
So if it ran good and is now an issue...Check for a loose connection. Probably a ground.
Check with a voltmeter on Ohm setting and see where you have the highest resistance. If all that is good, check positive wires with a test light and wiggle them while testing.
If all my bad advice fails....Call Rich at FastManEFI on here....
Re: EZ EFI No Start condition/ COMM ERROR [Re: RV2] #2374965
09/22/17 12:15 PM
09/22/17 12:15 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
COMM ERROR in general refers to network communications. Is there an external control module with a twisted pair buss wires? As stated before, check powers and grounds, but also check anything relative to buss network wiring. Anything that will stop any talking to the rest of the system (ie: throttle bodies) should be suspect. After that, it is usually an internal controller failure.
Note: This is all my opinion from my experience as a Level 3 Chrysler Tech and shop foreman.
[image][/image]
Re: EZ EFI No Start condition/ COMM ERROR [Re: sgcuda] #2375960
09/24/17 03:54 PM
09/24/17 03:54 PM
Dragula Offline
Dragula  Offline
An MSD can probably interfere with it as well if its close by or the wires for it are.
Re: EZ EFI No Start condition/ COMM ERROR [Re: RV2] #2376023
09/24/17 07:04 PM
09/24/17 07:04 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I still haven't heard from fast,no emails or calls yet, this system(including the ignition) has been on my car since 2010 and it's been trouble free till now.
The computer does not light up anymore so I assume that's the main problem.
Re: EZ EFI No Start condition/ COMM ERROR [Re: RV2] #2376039
09/24/17 07:55 PM
09/24/17 07:55 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Looks like the ECU has failed. Ship it back.
Re: EZ EFI No Start condition/ COMM ERROR [Re: Mopar_Rich] #2376057
09/24/17 09:05 PM
09/24/17 09:05 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
If I can get in contact with someone at fast I will.
Thanks for the replies
