Dana 60 Inner Axle Seals #2373501
09/19/17 07:37 PM
09/19/17 07:37 PM
South San Francisco, Ca
70sixpkrt Offline OP
What is the National Oil Seal part # for a Dana 60? It's for a 1970 Dodge Charger R/T. Is it 473228?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373668
09/20/17 12:00 AM
09/20/17 12:00 AM
I dont have an answer but what I would do is Google/ebay that info/number.
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373686
09/20/17 12:28 AM
09/20/17 12:28 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Isn't the bearings seals and other related parts the same as an 8 3/4?
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373689
09/20/17 12:34 AM
09/20/17 12:34 AM
I was told that the seals are different from 8 3/4 and Dana 60. The original ones says National 34419 but those are old numbers. My parts guy says the new numbers are Timken 473228. I just want to verify that before I put them in.
4-speed
3:54 Dana
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373795
09/20/17 08:52 AM
09/20/17 08:52 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Rock auto shows Nat. #8695S inner & 8740S outer 8.75 & Spicer 60.I do believe your right about them being different between 8.75 & 60 I just recently had a guy show me this I can contact him if needed.
Re: Dana 60 Inner Axle Seals [Re: 71GTX471] #2373796
09/20/17 09:02 AM
09/20/17 09:02 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
8695S would not fit my dana.....
read here.... "https://board.moparts.org/ubbthreads/ubbthreads.php/topics/12625/re-dana-60-axle-seal-question-update.html#Post12625"
jess
Yeah, it's hopped up to over 160...
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373797
09/20/17 09:15 AM
09/20/17 09:15 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I just reached out to my friend he used to rebuild differential's for a living & has all the older Spicer manuals. Why would R.A.show a part# for inner seals don't they only have the one outer.
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373849
09/20/17 12:09 PM
09/20/17 12:09 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
FPM: 8-3/4" & 9-3/4" both use 2404216 outer seal. 8-3/4" uses 2404215 which supersedes to 2881185 inner. 9-3/4" uses 2852574
inner.
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373918
09/20/17 03:07 PM
09/20/17 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From the archives:
Wheel seals: 8 3/4" and 70-72 Dana 60 inner 8695S, and outer 8704S.
Wheel seal inner: 66-70 B body Dana 60: 481837 and 8704S outer.
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373924
09/20/17 03:14 PM
09/20/17 03:14 PM
I have both 51098 and 473228. The first one is thicker than the other one. On the face of my original it says 34419. I am going to pull the seals out tomorrow and compare them.
4-speed
3:54 Dana
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2373941
09/20/17 03:46 PM
09/20/17 03:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
I believe that there are three different inner seals for the Mopar Dana 60 car rear ends, one for each size axle. the 1970/71 with the 35 spline axles will use the one for those axles only scope
The 1966/67 17 splines and the 1968/69 with the 23 splines are different ones shruggy
Re: Dana 60 Inner Axle Seals [Re: John_Kunkel] #2374858
09/22/17 01:26 AM
09/22/17 01:26 AM
Originally Posted By John_Kunkel
From the archives:
Thank you
4-speed
3:54 Dana
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2374970
09/22/17 12:21 PM
09/22/17 12:21 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
On my 1969 Coronet with Dana 60, I had a hard time finding the correct axle tube seals. Every place I looked kept giving the 8-3/4" part number and that seal is too small of an outer diameter.
I thought I posted the correct part number here, but I did not see it when I searched. I don't know off the top of my head what the part number is.
Re: Dana 60 Inner Axle Seals [Re: 70sixpkrt] #2374994
09/22/17 12:50 PM
09/22/17 12:50 PM
There are 3 different seals with 3 different widths for the Dana 60. My originals said National 34419 which I'm finding out was a Spicer part #.
473228 - 1.5000 x 2.5060 x 0.3125 (Double Lip)
481837 - 1.5000 x 2.5060 x 0.3750 (Single Lip) * Same width as my originals*
51098 - 1.5000 x 2.5060 x 0.4375 (Single Lip)
You don't know which ones you need until you pull out your original ones. That's what I'm finding out.
4-speed
3:54 Dana
