SRP 213455 Pistons and Head Gasket Choice
#2373611
09/19/17 10:41 PM
09/19/17 10:41 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
Building a stock stroke Eddy headed 440 w/LY rods for a customer using above mentioned SRP pistons. They are about .020 below the deck and with the current Fel Pro gasket compressed thickness of .039 I'm coming up with a compression ratio of about 9.74:1. Would going to a Cometic with .028 compressed thickness be a very noticeable improvement and worth the trouble? Customers car is a 74 Cuda with Edelbrock Projection fuel injection. Nice street car.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
Re: SRP 213455 Pistons and Head Gasket Choice
[Re: ChrgrCuda]
#2373691
09/20/17 12:39 AM
09/20/17 12:39 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Very little difference. Different animal but we went from 55 to 28 gasket on my smallblock, and cut the heads 50 thou and both these iteams moved compression up 1 point. What your considering doing is probably a 1/10 of a point.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Pacnorthcuda]
#2373741
09/20/17 02:15 AM
09/20/17 02:15 AM
ChrgrCuda
Texas, USA
I'm installing the 84cc Edelbrock Performer Heads. I'm wondering how much performance would be gained if I have the heads milled down to perhaps 80cc?
[Re: ChrgrCuda]
#2373943
09/20/17 03:51 PM
09/20/17 03:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Why not just cut the block .020 so its close or at zero then use the heads with the .039 gaskets
[Re: MR_P_BODY]
#2373950
09/20/17 04:06 PM
09/20/17 04:06 PM
ChrgrCuda
Texas, USA
I'm just having the Edelbrock heads milled to a 75cc chamber. This should yield me around 10.56:1.
