Re: Why are these spacers on the trans mount?
[Re: AndyF]
#2371876
09/16/17 09:06 PM
09/16/17 09:06 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Yup, that's what I think.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: AndyF]
#2371900
09/16/17 10:24 PM
09/16/17 10:24 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
I think all, the early, Pre 1966 4 speed cars came with them and not so on the automatics I've seen them on both A,B and E body cars since then I use them on both types of tranny now , I'll make them if needed also
[Re: AndyF]
#2371914
09/16/17 10:44 PM
09/16/17 10:44 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
My 65 B Body 4 spreed looks nothing like that and never has had spacers.Rocky
Chrysler Firepower
[Re: AndyF]
#2371997
09/17/17 12:32 AM
09/17/17 12:32 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Now if I can find a decent quality mount that actually fits the factory bolts
Man these mounts from Napa - Advance Auto - O Reilly's are all the same cheap junk
Mancini Racing I was told out of stock
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: GoodysGotaCuda]
#2372064
09/17/17 03:34 AM
09/17/17 03:34 AM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does the mount have slots? Typically something like that will be used to make up for a slot, or enlarged hole in the part it's touching. Yup, the slotted holes allow for variations in the body dimensions.
[Re: Diplomat360]
#2373348
09/19/17 03:25 PM
09/19/17 03:25 PM
John_Kunkel
Rio Linda, CA
Aren't these spacers meant to allow you to adjust the front driveline angle? The angle shims are one-piece and span both bolt holes.
#2373414
09/19/17 05:13 PM
09/19/17 05:13 PM
Posts: 31,050 Oregon
AndyF
Does the mount have slots? Typically something like that will be used to make up for a slot, or enlarged hole in the part it's touching. The trans mount that I have does not have slots but I think it is supposed to have slots. Might be a bad Chinese copy of the original. I understand the purpose of the washers if the trans mount has slots in it. I think I was confused by two things. The FSM calls these washers "spacers" when they aren't really spacers and the fact that my mount didn't have slots in it. I ordered a new trans mount since the one I have seems to put the engine a little further ahead of where it should be. If the mount was slotted I could slide the engine back to where it used to be.
[Re: Dr Dave]
#2373574
09/19/17 09:47 PM
09/19/17 09:47 PM
AndyF
Can't you slot the holes in your existing mount? I could but Summit has OE type mounts for less than $10 and the poly ones are around $45. I'd rather just order a new mount than spend the time taking my old mount over to a machine shop and waiting a few days for them to mess with it.
[Re: John_Kunkel]
#2373727
09/20/17 01:36 AM
09/20/17 01:36 AM
Posts: 1,762 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Aren't these spacers meant to allow you to adjust the front driveline angle? The angle shims are one-piece and span both bolt holes. I stand corrected, sorry guys...I went back to my '80 FSM and found the following in 16-3 section (Propeller Shaft and Universal Joints): Angle Correction ================ Front ... (1) Remove mount bolts and use transmission jack to raise extension for installation of shims. Each 1/8 inch shim will reduce the angle 1/4 degree ...
[Re: John_Kunkel]
#2374046
09/20/17 07:14 PM
09/20/17 07:14 PM
AndyF
Does the mount have slots? Typically something like that will be used to make up for a slot, or enlarged hole in the part it's touching. Yup, the slotted holes allow for variations in the body dimensions. I think I might have figured out the issue. The poly mount showed up today and dropped right in. The engine is now back where it is supposed to be. Seemed odd to me that an aftermarket part fit better than an original so I took a close look at the factory mount. It has a Chrysler number on it 3633580 so I assumed it was the correct mount. But when I try to look up that number in the parts book I come up empty. So now I'm thinking that it is a Chrysler tranny mount for something else, maybe a light truck?? That would explain why it didn't fit even though it was close. It moved the engine about 1/2 inch forward which was too much for the other mounts to take up. I just fooled myself since I "assumed" it was the correct mount. Glad I bought a different mount, I could've chased my tail on this thing for a good while before I figured it out.
