Timken Bearings Questions #2372943
09/18/17 09:09 PM
09/18/17 09:09 PM
Wausau Wi
Convertcuda Offline OP
Wausau Wi
Does anyone know the correct part numbers for Timken Inner and outer bearing for a 70 Cuda front rotor? These are original rotors. Does Timken make the seal also?
Thanks Ken
Re: Timken Bearings Questions [Re: Convertcuda] #2372970
09/18/17 09:41 PM
09/18/17 09:41 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I'm sure timkin still makes it all.
I don't have a catalog right now but iirc the outter bearings are set 2.
Check Rock Auto and see what number they provide.
Angry white pureblood male
Re: Timken Bearings Questions [Re: Convertcuda] #2372979
09/18/17 09:55 PM
09/18/17 09:55 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do you want US made TimKen bearings, or china made Timken bearings?
Re: Timken Bearings Questions [Re: 71birdJ68] #2372984
09/18/17 10:07 PM
09/18/17 10:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
As noted, not all Timkens are the same anymore. You have to be careful which ones you get. Many are made in eastern Europe and are not at all like the U.S. made ones.
Master, again and still
Re: Timken Bearings Questions [Re: 71birdJ68] #2373013
09/18/17 10:48 PM
09/18/17 10:48 PM
Wausau Wi
Wausau Wi
I would like the usa ones of course.
Re: Timken Bearings Questions [Re: Convertcuda] #2373050
09/19/17 12:01 AM
09/19/17 12:01 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do you have your old bearings? If so, I can tell you how to get them.
Re: Timken Bearings Questions [Re: 71birdJ68] #2373051
09/19/17 12:02 AM
09/19/17 12:02 AM
Wausau Wi
Wausau Wi
I will take a look and reply tomorrow.
Re: Timken Bearings Questions [Re: Convertcuda] #2373189
09/19/17 10:27 AM
09/19/17 10:27 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Give me a call at 423-312-6962. To much of this back and forth typing.
