Re: hooker comp headers for 69 b body
[Re: moparpro]
#2373398
09/19/17 04:38 PM
09/19/17 04:38 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Doug's D452 is the best header I have ever used and costs less than TTi Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: moparpro]
#2373537
09/19/17 08:29 PM
09/19/17 08:29 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
As stated, the Hooker Comps are a bit of a pain to get in and out, but once they're in.... They have pretty good access to everything(IMO). Overall, I'm pretty happy with the fit.
If you're running angle plug heads, some dinging will be required on the right side header.
[Re: fourgearsavoy]
#2373991
09/20/17 05:33 PM
09/20/17 05:33 PM
Posts: 3,344 Central TX
roe
Central TX
Doug's D452 is the best header I have ever used and costs less than TTi Gus Absolutely agree. I put in a set of their ceramic coated headers and the went in smooth and have held up great over the years. I also have easy access to all plugs.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
