1969 Hemi Water Pump Pulley Identification #2371699
09/16/17 01:54 PM
09/16/17 01:54 PM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
What are the dimensions of a 1969 Hemi water pump pulley? Would be part number 2946716. Same pulley from 69 thru 71 I believe. No part number stamped on the one I'm looking at. Is there a way to positively identify one. Has this been discussed before?
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2372144
09/17/17 12:15 PM
09/17/17 12:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2372245
09/17/17 03:22 PM
09/17/17 03:22 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1969 changed the pullies on this engine, not the same as 68 and older.
Re: 1969 Hemi Water Pump Pulley Identification [Re: NANKET] #2372291
09/17/17 05:42 PM
09/17/17 05:42 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
My 1967 parts book lists 1821452 for the Hemi engine fan pulley (same as B and RB) My 1968 parts book lists 2946716 as the Hemi fan pulley. My 1969 parts book also lists 2946716 as the Hemi fan pulley. shruggy
Re: 1969 Hemi Water Pump Pulley Identification [Re: 6PakBee] #2372764
09/18/17 03:28 PM
09/18/17 03:28 PM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
I have no explanation as to why the 68 book calls out the 2946716 pulley. My understanding was 69 and up on that pulley. But no matter I'm just looking for dimensions on the 2946716 pulley or how to identify one.
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2372806
09/18/17 04:27 PM
09/18/17 04:27 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Perhaps this list was generated from the parts books but it agrees with them.
http://www.440source.com/pulleyswaterpump.htm
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2373872
09/20/17 01:02 PM
09/20/17 01:02 PM
Canada
Maxwellwedge Offline
Canada
They are a lot smaller than a 440 pulley.
I'll try and measure one up for you...and take a pic
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2374129
09/20/17 09:04 PM
09/20/17 09:04 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
How good are you at scaling photos Dave? I had three NOS sets of pulleys, but they are all sold now...
Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge] #2376300
09/25/17 10:58 AM
09/25/17 10:58 AM
Canada
Canada
Here you go.....5-1/2" diameter x 2-1/8" high
Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge] #2377999
09/27/17 10:50 PM
09/27/17 10:50 PM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
Thanks Jim for taking the time to measure and post pics of the pulley. Saved me buying what I now believe to be an incorrect pulley. Oh well the search goes on. Part of the fun I guess.
Much Appreciated!!!
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2378176
09/28/17 10:50 AM
09/28/17 10:50 AM
Canada
Canada
Happy to do it.
Good luck on your search for a correct one!
Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge] #2378700
09/29/17 10:11 AM
09/29/17 10:11 AM
moparx Offline
moparx  Offline
max, was the crank pulley smaller than the wedge , or around the standard 7 1/4" size ?
beer
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2378757
09/29/17 12:05 PM
09/29/17 12:05 PM
Canada
Canada
It's definitely different - I'll see if I can snap a pic over the weekend
Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge] #2380458
10/02/17 10:43 AM
10/02/17 10:43 AM
Canada
Canada
Here is a pic from my 70 engine....
Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge] #2381696
10/04/17 11:59 AM
10/04/17 11:59 AM
moparx Offline
moparx  Offline
thanks max ! up
beer
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2382663
10/05/17 09:07 PM
10/05/17 09:07 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Crank pully is also shorter, H Balancer is thicker
Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona] #2382832
10/06/17 03:08 AM
10/06/17 03:08 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
There is info about this in the '69 factory service manual for Hemi:
"Ratio (Fan to Crankshaft) 1.20:1"
If the water pump pulley and the fan are turning together, then the diameter of the original water pump pulley is 1.20 times the original crankshaft pulley.
