#2371699 - 09/16/17 11:54 AM 1969 Hemi Water Pump Pulley Identification
Davtona Offline
Loc: Iowa
What are the dimensions of a 1969 Hemi water pump pulley? Would be part number 2946716. Same pulley from 69 thru 71 I believe. No part number stamped on the one I'm looking at. Is there a way to positively identify one. Has this been discussed before?
#2372144 - 09/17/17 10:15 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
6PakBee Online   content
Loc: North Dakota
Edited by 6PakBee (09/27/17 12:22 PM)
Wife says too many cars, liquidation coming soon......
#2372245 - 09/17/17 01:22 PM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
NANKET Offline
Loc: northwest USA
1969 changed the pullies on this engine, not the same as 68 and older.
#2372291 - 09/17/17 03:42 PM Re: 1969 Hemi Water Pump Pulley Identification [Re: NANKET]
Loc: North Dakota
My 1967 parts book lists 1821452 for the Hemi engine fan pulley (same as B and RB) My 1968 parts book lists 2946716 as the Hemi fan pulley. My 1969 parts book also lists 2946716 as the Hemi fan pulley. shruggy
#2372764 - 09/18/17 01:28 PM Re: 1969 Hemi Water Pump Pulley Identification [Re: 6PakBee]
Davtona Offline
Loc: Iowa
I have no explanation as to why the 68 book calls out the 2946716 pulley. My understanding was 69 and up on that pulley. But no matter I'm just looking for dimensions on the 2946716 pulley or how to identify one.
#2372806 - 09/18/17 02:27 PM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
Loc: North Dakota
Perhaps this list was generated from the parts books but it agrees with them.
http://www.440source.com/pulleyswaterpump.htm
#2373872 - 09/20/17 11:02 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
Maxwellwedge Offline
Loc: Canada
They are a lot smaller than a 440 pulley.
I'll try and measure one up for you...and take a pic
#2374129 - 09/20/17 07:04 PM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
xs29j8 Offline
Loc: Fort Worth, Texas
How good are you at scaling photos Dave? I had three NOS sets of pulleys, but they are all sold now...
#2376300 - 09/25/17 08:58 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge]
Loc: Canada
Here you go.....5-1/2" diameter x 2-1/8" high
#2377999 - 09/27/17 08:50 PM Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge]
Davtona Offline
Loc: Iowa
Thanks Jim for taking the time to measure and post pics of the pulley. Saved me buying what I now believe to be an incorrect pulley. Oh well the search goes on. Part of the fun I guess.
Much Appreciated!!!
#2378176 - 09/28/17 08:50 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
Loc: Canada
Happy to do it.
Good luck on your search for a correct one!
#2378700 - 09/29/17 08:11 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge]
moparx Online   content
Dreaming of implants
Loc: north of coder
max, was the crank pulley smaller than the wedge , or around the standard 7 1/4" size ?
beer
#2378757 - 09/29/17 10:05 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
Loc: Canada
It's definitely different - I'll see if I can snap a pic over the weekend
#2380458 - 10/02/17 08:43 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge]
Loc: Canada
Here is a pic from my 70 engine....
#2381696 - 10/04/17 09:59 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Maxwellwedge]
Loc: north of coder
thanks max ! up
beer
#2382663 - 10/05/17 07:07 PM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
cudaman1969 Offline
Loc: fredericksburg,va
Crank pully is also shorter, H Balancer is thicker
#2382832 - 10/06/17 01:08 AM Re: 1969 Hemi Water Pump Pulley Identification [Re: Davtona]
kentj340 Offline
Loc: Houston
There is info about this in the '69 factory service manual for Hemi:
"Ratio (Fan to Crankshaft) 1.20:1"
If the water pump pulley and the fan are turning together, then the diameter of the original water pump pulley is 1.20 times the original crankshaft pulley.
25,383 Registered Members
191,014 Topics
Rear suspension options for healthy bigblock on the street
by radar
07/22/18 10:26 AM
Installing Alternator pulley's
by sixpackman
07/22/18 09:47 AM
Carb Tech pls school me choosing the right Booster
by 1964Polara
07/22/18 08:18 AM
360 build opinions
by Eggman
07/22/18 08:07 AM
