pics of convertible top header panel
#2372566
09/18/17 08:37 AM
09/18/17 08:37 AM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
Does anyone have a good pic of a convertible top front header frame panel? A friend of mine is having his top replaced and found that the header frame panel is rotted badly. It looks like the top material gets attached to it but someone had it bondo'd up but looks like there was a recessed area on the corners of the header panel. If I can get a good pic for him, I'm sure he can fabricate something as he does an amazing job with custom metal work.
Thanks.
inherited a 69 roadrunner from my grand pop.
Re: pics of convertible top header panel
[Re: fuelishnsilly]
#2372609
09/18/17 11:15 AM
09/18/17 11:15 AM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Thanks. Really common area/part to rust out... Had a body man cut out most the bad and weld in new metal on mine..
[Re: fuelishnsilly]
#2372797
09/18/17 04:18 PM
09/18/17 04:18 PM
fuelishnsilly
Greenwood Lake, NY
Floridian,
Thanks for the info. Thats what he assumed also but it seemed like there was a recessed area on each end. He can fabricate something but needs a pic of what it supposed to look like. Shame no one makes repros of these since they are such a common area to rust out.
[Re: fuelishnsilly]
#2373959
09/20/17 04:19 PM
09/20/17 04:19 PM
fuelishnsilly
Greenwood Lake, NY
awesome. can you take just a picture of that flat recessed area on the top where those holes are? The underside of his is good. Its just the top area where those holes were that is one giant hole now. Also, what were those hose there for? Did it hold the top material down to the header? If so, were they screwed or pop riveted? his had pop rivets holding it down but his also had a ton of plastic filler in there too so I doubt that was correct.
[Re: fuelishnsilly]
#2379169
09/30/17 02:00 AM
09/30/17 02:00 AM
fuelishnsilly
Greenwood Lake, NY
Perfect. That bottom pic with the screw holes is what he needed. Where the top padding goes and screws into the header panel, thats right where his is completely rotted out. I did see some screw holes which now I know why they were there for the top padding.
Thank you so much for the pics ! He is extremely appreciative !
[Re: fuelishnsilly]
#2383603
10/07/17 10:13 PM
10/07/17 10:13 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
thanks for those pictures 70runner
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
