Re: Projected tip plugs more prone to detonation?
[Re: davenc]
#2372359
09/17/17 08:09 PM
09/17/17 08:09 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
[Re: davenc]
#2372401
09/17/17 09:57 PM
09/17/17 09:57 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I use this type in my 512, they work great. the spark is not shrouded by the ground strap.
[Re: mopar dave]
#2372498
09/18/17 01:36 AM
09/18/17 01:36 AM
CSK
Pattison Texas
those are interesting. whats the part number on those? bkr6ek & a step hotter bkr5ek NGK I run the 5 in my 9.5to1 512 street car. 4000 miles on them & some track passes, no missfires & they still look great. no signs of detonation.
[Re: davenc]
#2372541
09/18/17 03:17 AM
09/18/17 03:17 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Regular NGKs at $20 a set.Especially when you reading plugs!
[Re: CSK]
#2372663
09/18/17 12:33 PM
09/18/17 12:33 PM
Thumperdart
State of confusion
those are interesting. whats the part number on those? bkr6ek & a step hotter bkr5ek NGK I run the 5 in my 9.5to1 512 street car. 4000 miles on them & some track passes, no missfires & they still look great. no signs of detonation. In NGK's, the higher the number the COLDER the plug unless that weird sukka is different........... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Thumperdart]
#2372702
09/18/17 01:34 PM
09/18/17 01:34 PM
CSK
Pattison Texas
those are interesting. whats the part number on those? bkr6ek & a step hotter bkr5ek NGK I run the 5 in my 9.5to1 512 street car. 4000 miles on them & some track passes, no missfires & they still look great. no signs of detonation. In NGK's, the higher the number the COLDER the plug unless that weird sukka is different........... yep,they follow the same as all NGK.
[Re: BradH]
#2372804
09/18/17 04:26 PM
09/18/17 04:26 PM
Thumperdart
State of confusion
An NGK "5" would scare me. I'm not sure I'd use anything hotter than a "7" even for a regular street car, but a lot of that is based on my experience with too-hot heat ranges used in motorcycles. Went 9.79 @ 135+ several years ago first pass ever w/the new combo and a # 7 and my carb was lean as in the 14's up top and saw a tiny bit of peppering so now I run 8's at 12.1.1 comp.........
[Re: AndyF]
#2372983
09/18/17 10:00 PM
09/18/17 10:00 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I'm sure I've posted this picture before but here are three plugs I tested in my 470 with the Trick Flow heads. These are all the same heat range and the same brand. Standard, projected and super projected. I use the super projected just because it seems like it should be better but I did not notice any difference on the dyno between the three plugs. Sure would like to see a comparative timing strap read on those three plugs after a good pull. Sure seems that the projected plugs would be risky in a power adder situation.
[Re: davenc]
#2372985
09/18/17 10:07 PM
09/18/17 10:07 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
I run the NGK BKR6E in my 505 , same plug in my 440 . 505 is 11:1. Never any issues . Under 10:1 NA I would run -5 These are projected plugs. Only thing with NGK's is they hate being over fuelled .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2373092
09/19/17 01:28 AM
09/19/17 01:28 AM
Thumperdart
State of confusion
Tex That's good info and I like the fact that you race it and get real world tested info which is helpful for some of us in a similar scenario.......Dyno stuff for sure has it's place especially a chassis dyno in a real world load zone simulating going down the street or track but, I still have tried adding more fuel, timing air pressure and launch/suspension settings to get more out of my car and a few others along the way............ ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Thumperdart]
#2373099
09/19/17 01:38 AM
09/19/17 01:38 AM
tex013
Sydney,Australia
Tex That's good info and I like the fact that you race it and get real world tested info which is helpful for some of us in a similar scenario.......Dyno stuff for sure has it's place especially a chassis dyno in a real world load zone simulating going down the street or track but, I still have tried adding more fuel, timing air pressure and launch/suspension settings to get more out of my car and a few others along the way............ Maate ! I am only a slowpoke compared with most on here . Tex
