Page 1 of 4 1 2 3 4
Projected tip plugs more prone to detonation? #2372344
09/17/17 07:22 PM
09/17/17 07:22 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Are projected tip plugs more prone to detonation, as compared to the equivalent non-projected tip plug?
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372353
09/17/17 08:01 PM
09/17/17 08:01 PM
AndyF Offline
AndyF  Offline
Probably depends on the combustion chamber design. I use the extra projected, extra wide gap plugs on my pump gas engines. Same part number that the factory puts into the modern engines.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372359
09/17/17 08:09 PM
09/17/17 08:09 PM
Not if you get the heat range and timing correct for that motor up work
I like and always use them on all my N/A motors up
you should always strive to get the spark as close to the center of the piston as possible work up
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372401
09/17/17 09:57 PM
09/17/17 09:57 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I use this type in my 512, they work great. the spark is not shrouded by the ground strap.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372406
09/17/17 10:07 PM
09/17/17 10:07 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Thanks for the feedback. Anyone see value to iridium plugs? I know the OEMs use them for longevity, but the fine tip seems to produce a well concentrated spark. Would that be beneficial to power production?
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2372408
09/17/17 10:12 PM
09/17/17 10:12 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
those are interesting. whats the part number on those?
Re: Projected tip plugs more prone to detonation? [Re: mopar dave] #2372498
09/18/17 01:36 AM
09/18/17 01:36 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
bkr6ek & a step hotter bkr5ek NGK I run the 5 in my 9.5to1 512 street car. 4000 miles on them & some track passes, no missfires & they still look great. no signs of detonation.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372541
09/18/17 03:17 AM
09/18/17 03:17 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Regular NGKs at $20 a set.Especially when you reading plugs!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2372551
09/18/17 04:24 AM
09/18/17 04:24 AM
Mt Morris Michigan
Mt Morris Michigan
Ill check those out. Thanks
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2372663
09/18/17 12:33 PM
09/18/17 12:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
In NGK's, the higher the number the COLDER the plug unless that weird sukka is different........... thumbs
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2372702
09/18/17 01:34 PM
09/18/17 01:34 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
yep,they follow the same as all NGK.
Re: Projected tip plugs more prone to detonation? [Re: CSK] #2372737
09/18/17 02:33 PM
09/18/17 02:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
An NGK "5" would scare me. I'm not sure I'd use anything hotter than a "7" even for a regular street car, but a lot of that is based on my experience with too-hot heat ranges used in motorcycles.
Re: Projected tip plugs more prone to detonation? [Re: Cab_Burge] #2372748
09/18/17 02:43 PM
09/18/17 02:43 PM
BradH Offline
BradH  Offline
Originally Posted By Cab_Burge
... I like and always use them on all my N/A motors up
x2, especially with BB Mopar heads that have the plug sitting almost back to the cylinder wall.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372768
09/18/17 03:33 PM
09/18/17 03:33 PM
AndyF Offline
AndyF  Offline
I'm sure I've posted this picture before but here are three plugs I tested in my 470 with the Trick Flow heads. These are all the same heat range and the same brand. Standard, projected and super projected. I use the super projected just because it seems like it should be better but I did not notice any difference on the dyno between the three plugs.
Re: Projected tip plugs more prone to detonation? [Re: BradH] #2372804
09/18/17 04:26 PM
09/18/17 04:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Went 9.79 @ 135+ several years ago first pass ever w/the new combo and a # 7 and my carb was lean as in the 14's up top and saw a tiny bit of peppering so now I run 8's at 12.1.1 comp......... thumbs
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372966
09/18/17 09:38 PM
09/18/17 09:38 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
I think CR plays a big factor. I was using regular tip NGK -7 plugs in my 10.3:1 470 street car, and have been having an issue keeping them clean and would have sporadic misfires driving around town. I changed to some used Autolite 3923 (projected tip) and the plugs look better and I don't notice misfires now. I need to get new plugs and have been pondering what to get. Given my recent tests, I plan on going with -6 but still need to decide exactly which type to get. The "super projected tip" plugs look interesting. Also thinking about trying the fine tip iridiums as an experiment.
Re: Projected tip plugs more prone to detonation? [Re: AndyF] #2372983
09/18/17 10:00 PM
09/18/17 10:00 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Sure would like to see a comparative timing strap read on those three plugs after a good pull. Sure seems that the projected plugs would be risky in a power adder situation.
Re: Projected tip plugs more prone to detonation? [Re: davenc] #2372985
09/18/17 10:07 PM
09/18/17 10:07 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run the NGK BKR6E in my 505 , same plug in my 440 . 505 is 11:1.
Never any issues . Under 10:1 NA I would run -5
These are projected plugs.
Only thing with NGK's is they hate being over fuelled .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Projected tip plugs more prone to detonation? [Re: tex013] #2373092
09/19/17 01:28 AM
09/19/17 01:28 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Tex
That's good info and I like the fact that you race it and get real world tested info which is helpful for some of us in a similar scenario.......Dyno stuff for sure has it's place especially a chassis dyno in a real world load zone simulating going down the street or track but, I still have tried adding more fuel, timing air pressure and launch/suspension settings to get more out of my car and a few others along the way............ thumbs
Re: Projected tip plugs more prone to detonation? [Re: Thumperdart] #2373099
09/19/17 01:38 AM
09/19/17 01:38 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
Maate !
I am only a slowpoke compared with most on here .
Tex
New best MPH 130.32
Page 1 of 4 1 2 3 4
