Tachometer reads too high #2372234
09/17/17 03:08 PM
09/17/17 03:08 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
The stock tach on my Rallye dash 440 Challenger reads too high, at least 1000 rpm, it seems to be just at the higher rpms.
The speedo seems pretty accurate..3.23 gears.
What could be wrong?
Re: Tachometer reads too high [Re: Moparmaniacc] #2372286
09/17/17 05:27 PM
09/17/17 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've never seen a factory tach that didn't read high. What type of ignition are you running, anything but original makes it worse.
Consider upgrading the tach with modern electronics.
http://www.tachman.com/mopar.htm
Re: Tachometer reads too high [Re: Moparmaniacc] #2372290
09/17/17 05:40 PM
09/17/17 05:40 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
My in dash tach reads about 100 to 200 RPM more than it should be too.
Re: Tachometer reads too high [Re: Moparmaniacc] #2372309
09/17/17 06:15 PM
09/17/17 06:15 PM
BDW Offline
BDW  Offline
Whatever you do, DO NOT use tachman,
By far the worst auto experience I've ever had!
Re: Tachometer reads too high [Re: Moparmaniacc] #2372311
09/17/17 06:25 PM
09/17/17 06:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
RT engineering also has a modern tach board.
Re: Tachometer reads too high [Re: Moparmaniacc] #2372318
09/17/17 06:40 PM
09/17/17 06:40 PM
Northern Virginia
Northern Virginia
Thanks guys, I'll check them out!
