BB distributor lock collar... Does this look right? #2371734
09/16/17 03:21 PM
09/16/17 03:21 PM
USA
JoesMopar Offline OP
USA
I got my lock collar on and about to drop in the distributor. I've never used one of these and almost rather would leave it off but maybe I can be reassured it will be fine...
Does this look right? I know you don't know what my clearance is from the picture but just in general. I didn't use loctite on the set screw yet... Not sure if I should. Thanks
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2371740
09/16/17 03:37 PM
09/16/17 03:37 PM
Kirkland, Washington
Pacnorthcuda Offline
Yes that looks right. I would use blue loctite.
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2371755
09/16/17 03:59 PM
09/16/17 03:59 PM
USA
USA
Thanks a lot
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2371799
09/16/17 06:02 PM
09/16/17 06:02 PM
first I would drive out the roll pin in the plastic collar & add flat shims (speedway has a kit for $10) to reduce the axial clearance to .005". Yes blue loctite & I'm assuming you put the collar on snug then set the dist in place down in there to set the height then carefully removed the dist then tightened up the setscrew.
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2371802
09/16/17 06:18 PM
09/16/17 06:18 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
What's the purpose here? Does the gear want to lift off the cam?
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2371814
09/16/17 06:53 PM
09/16/17 06:53 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
scope shruggy
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: BB distributor lock collar... Does this look right? [Re: 3hundred] #2371840
09/16/17 07:50 PM
09/16/17 07:50 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That's just the 2 way male/female connector thingy laying on the table there I imagine....
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2371865
09/16/17 08:49 PM
09/16/17 08:49 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Always thought the lock collar went up against the body of distributor so the shaft would not move up & down . . . usually there is a spot there for the roll pin to go through the distributor shaft . . . the gear won't move, as the distributor is held down on with the upper outside collar . . .
Re: BB distributor lock collar... Does this look right? [Re: a12rag] #2371879
09/16/17 09:14 PM
09/16/17 09:14 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The dist shaft does not bottom out on the oil pump shaft, there is a lot of clearance there for the oil pump shaft to move up & down,, & it does,,fixed many of them with the lock collar like the OP. is doing. before, timing light jumps all over,, after, nice & steady
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2371892
09/16/17 09:56 PM
09/16/17 09:56 PM
Alberta
440_Offroader Offline
Alberta
I may be wrong, but I thought 'the bouncing timing thing' was a small block issue,due to the cw rotation. I've never had any of my big blocks have their timing bouncing around. My 360 definitely has the timing fluctuations (which I need to fix someday). Maybe I've just been lucky with my big blocks?
Re: BB distributor lock collar... Does this look right? [Re: 440_Offroader] #2371938
09/16/17 11:18 PM
09/16/17 11:18 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Mine is a big block, & it did jump around, clock,or counter direction has no bearing on timing fluctuation.
Re: BB distributor lock collar... Does this look right? [Re: CSK] #2372037
09/17/17 01:46 AM
09/17/17 01:46 AM
Alberta
Alberta
Good to know.
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2372100
09/17/17 09:45 AM
09/17/17 09:45 AM
BDW Online content
BDW  Online Content
Why not file a small flat spot or start a drill bit hole for the collar screw?
With all the vibration, even with locktite, seems like it would move.
I've heard just the opposite, it's a BB problem, not needed on SB because of the rotational direction. BB pushes up, SB is opposite direction.
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2372199
09/17/17 02:01 PM
09/17/17 02:01 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Never used one, never had a problem. If there is that much vibration between gears there is something wrong. I am still not really understanding the theory on these. The cam gear is forcing the intermediate shaft upwards which would take up any, other than oil, clearance. How would the intermediate shaft jump up and down if the gear is constantly forcing it up?
Re: BB distributor lock collar... Does this look right? [Re: Dave Hall] #2372206
09/17/17 02:17 PM
09/17/17 02:17 PM
The gear under load, WOT, versus coasting will change what it does in the motor shruggy
The timing changes and moving around are usually due to wear on the cam gear, oil pump gear, timing chain and slop between the distributor shaft and the slot in the oil pump gear scope
Re: BB distributor lock collar... Does this look right? [Re: Cab_Burge] #2372214
09/17/17 02:32 PM
09/17/17 02:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
What does engine speed have to do with it Cab? The gear continues to turn in the same direction??? The oil pump acts in shear loading not thrust. I actually don't see how there could be any slop between the dist. flat head and the gear slot if the gear is always forced up when the engine is turning.
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2372218
09/17/17 02:39 PM
09/17/17 02:39 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I filled the drive gear slot with a leather piece, which should make the same job adding a cushion as a plus, and still have the jumping timming at iddle
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2372220
09/17/17 02:43 PM
09/17/17 02:43 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I don't think jumping timing at idle is caused by this on a big block. It logically doesn't make sense. It's either, as Cab said, worn timing gear set or distributor.
Re: BB distributor lock collar... Does this look right? [Re: NachoRT74] #2372223
09/17/17 02:50 PM
09/17/17 02:50 PM
Happy birthday Nacho. I'm gonna kick back & watch some pro FOOTBALL today, (we don't do hand eggs). OP the main problem with it is alot of slop makes for spark scatter when timing it at idle as does slop in the timing chain. You're right when "loaded" when accellerating all the play is taken out but steady speed or letting off the gas it can & will fluctuate. Maybe not a dealbreaker but the builder who goes to the nth degree in all areas will be the one that gets to kiss the trophy girl.
Re: BB distributor lock collar... Does this look right? [Re: JoesMopar] #2372660
09/18/17 12:27 PM
09/18/17 12:27 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Thanks Robert, my Good friend!!! LOL. I was hearing the real football from Spanish league on the radio.
I do ( or did ) have the same problem... fit the leather piece into the slot which actually makes the same than the lock ring and still have the same jumping timming at iddle maybe +/- 2°or 3°. I wouldn't state that as a problem if just at iddle, because of course giving gas should be tight due the gears being loaded, however I would like to get a steady reading at iddle.
My car is toptally dissasembled anyway... will take care of that I hope next month.
allways read this kind of threads just on case I find something new.
