Indy Head owners #237186
02/26/09 06:49 PM
02/26/09 06:49 PM
U.S.
moparniac Offline OP
U.S.
My first set of heads and I ran a bead across the valley plate end rails and put the heads on and it seems the heads dont go to the top of the cutangel... ??? I also ran another bead across the channel.. thoughts??? is this normal....
also what is the valve angle of the indy ez heads. thx
Mopar Performance
Re: Indy Head owners [Re: moparniac] #237187
02/26/09 06:55 PM
02/26/09 06:55 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I encountered the same thing Wedge. I picked up my Valley plate used at a swap meet. it liked a good 1/4 before touching the head. I just ran a bead of sealer, let it dry, ran another on top of it. and bolted the clean head down while the sealer was a little tacky..
Re: Indy Head owners [Re: moparniac] #237188
02/26/09 06:57 PM
02/26/09 06:57 PM
Yes, you must seal the head to the valley plate with a bead of silicon...
Re: Indy Head owners [Re: Bob_Coomer] #237189
02/26/09 06:59 PM
02/26/09 06:59 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive got a set of sr,s and EZ-325,s they fit perfect.ive had the EZ,s on 3 different blocks mildly decked and no prob.
Re: Indy Head owners [Re: Bob_Coomer] #237190
02/26/09 07:03 PM
02/26/09 07:03 PM
UK
602heavy Offline
602heavy  Offline
UK
How come indy don't supply a gasket for this?
Got the Indy valley plate which has to go on before the heads (572-13s) , got an oil leak between heads & plate even though the heads were bolted down on a bed of sealer , seems the gap between heads & plate is a good 3/8".
Anyone else have this problem , as said above , WHY don't indy supply a gasket?
Re: Indy Head owners [Re: 602heavy] #237191
02/26/09 07:07 PM
02/26/09 07:07 PM
U.S.
U.S.
I set the head on with the sealer a little smudgy and then laid a bead across the gap and spread it smooth with my finger..
Mopar Performance
Re: Indy Head owners [Re: moparniac] #237192
02/26/09 07:12 PM
02/26/09 07:12 PM
U.S.
U.S.
whats the valve angle of a indy head.. just curious..
Mopar Performance
Re: Indy Head owners [Re: moparniac] #237193
02/26/09 07:16 PM
02/26/09 07:16 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We usually mill the sides off the valley plate so that we can remove it with the heads in place.We apply a heavy bead of black RTV and smooth it with our finger and remove any excess with a razor blade.Zero leaks.
Re: Indy Head owners [Re: moparniac] #237194
02/26/09 07:31 PM
02/26/09 07:31 PM
AndyF Offline
AndyF  Offline
That is why I ended up designing and making my own valley plates.
Re: Indy Head owners [Re: B G Racing] #237195
02/26/09 07:31 PM
02/26/09 07:31 PM
UK
602heavy Offline
602heavy  Offline
UK
That's a great idea Bob , thanks.
Or remove water pump etc & pull plate out from the front.
Re: Indy Head owners [Re: moparniac] #237196
02/26/09 08:09 PM
02/26/09 08:09 PM
nc
moeflo Offline
moeflo  Offline
nc
Through -1's they're the stock 15°.
Re: Indy Head owners [Re: moeflo] #237197
02/26/09 08:32 PM
02/26/09 08:32 PM
NC
440Jim Offline
440Jim  Offline
NC
The used setup I bought before the 2008 season seemed to fit fine. The gap for silicone was only maybe 1/16". Maybe you can see in this pic (open attachment) that the head doesn't go all the way to the top of the angle cut on the valley plate, but the gap is small.
Re: Indy Head owners [Re: moparniac] #237198
02/26/09 09:40 PM
02/26/09 09:40 PM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
572-13 heads are 13 degres, I bought a valey plate from Indy it had a large gap also so I measured it, It was 8 1/2 on one end and 8 3/8 on the other end witch caused an almost 3/16 gap I new it wouldnt seal so I sent it back for exchange. When they recived it I called them they claimed that the almost 3/16 gap was within spec, so I asked them to send me another one anyway, that was three weeks ago and I'm still waiting for it. So it looks like you all may have to live with that gap
Re: Indy Head owners [Re: JoWeTu_6] #237199
02/26/09 09:45 PM
02/26/09 09:45 PM
AndyF Offline
AndyF  Offline
The plates I make are CNC machined so they fit correctly. I make them so they are flush with the deck which leaves a gap of about 0.030 (head gasket thickness) that is filled in with RTV.
