PW wiring protection? #2371797
09/16/17 05:55 PM
09/16/17 05:55 PM
WNY
slimert Offline OP
slimert  Offline OP
WNY
Have a 68 Coronet with power windows. The wiring that runs between the frame and door grommets near the door hinges, the electrical tape (I think) that covered the wiring harness is long gone. Has anyone used a better tape or product to cover the wires?
Re: PW wiring protection? [Re: slimert] #2372767
09/18/17 03:32 PM
09/18/17 03:32 PM
Manitoba, Canada
70NetRT Offline
70NetRT  Offline
Manitoba, Canada
I was planning on using the 3M Temflex 1755 friction tape. It was recommended as a good replacement for the factory cloth wire wrap. Datasheet (.pdf)
Re: PW wiring protection? [Re: slimert] #2373853
09/20/17 12:24 PM
09/20/17 12:24 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
The factory wrapped harnesses with a tape that had no adhesive. Electrical tape leaves behind gunk when the vinyl unravels. Your wires are pretty clean so I do not think electrical tape was used, they would have old black goo on them.
This stuff works and this is not the only place to get it, just the easiest to find on a google search:
https://www.classicindustries.com/product/k0067.html
Craig
Re: PW wiring protection? [Re: denfireguy] #2374159
09/20/17 09:59 PM
09/20/17 09:59 PM
motor city
sixty9redgtx Offline
motor city
Cloth style electrical tape, not the plastic stuff
Re: PW wiring protection? [Re: slimert] #2376293
09/25/17 10:43 AM
09/25/17 10:43 AM
WNY
slimert Offline OP
slimert  Offline OP
WNY
I have have both tapes, the friction tape looks correct.
Thank you for the responses.
