1967 B-body No heat from heater... checked FSM. Any ideas? #2371778
09/16/17 05:02 PM
09/16/17 05:02 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Thanks for looking...
Fall is coming and I went to use the heat on our convertible - got nothing but cold air. It worked fine last year. I went though the Troubleshooting suggestions in the 1967 FSM and found nothing wrong: Blower works, the water flowing to/from the core feels hot on the hoses, the damper that directs the hot air seems to work, the airbox damper arm moves properly, the control cable is intact.
What would you check if you had no heat from your heater?
Can a heater core get clogged? My radiator fluid isn't ugly or anything..
I'm a little stumped. I think I'll just keep checking the FSM and everything again, I think I tried all the modes; floor heat vs defrost, but I'll keep checking..
Looking for any and all ideas. ....Drill some holes in the firewall..? smile
Thank you,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2371783
09/16/17 05:29 PM
09/16/17 05:29 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Sounds like a plugged/restricted core.
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: Skeptic] #2371785
09/16/17 05:32 PM
09/16/17 05:32 PM
Albany, NY
Albany, NY
OK. I'll let it get cold and when I start it next time check if the supply/return hoses get hot or if they stay cool, or what's what.
Thx. - Art
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2371789
09/16/17 05:38 PM
09/16/17 05:38 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
If you have an infrared temp gun, check for a 15-20F drop from the inlet-> outlet temps. You can also use that to check the heater box to see if it's heating up. Make sure there isn't a shut off valve under the dash, they can stick closed and cause the same issue. HTH, Steve
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2371828
09/16/17 07:27 PM
09/16/17 07:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When I was stationed in San Diego I had a 72 Swinger, one rare day it got cold enough to need a heater. No heat. usually that means you are low on coolant, but not in my case (did you check yours?). Turns out the core was plugged.
All I did was disconnect the heater hoses and use a garden hose to flush one way till the water ran clear, then the other way till it ran clear. Took a couple of times going back and forth till it ran clear both ways from the get go. Plenty of heat after that.
Don't be the exception.
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2371980
09/17/17 12:10 AM
09/17/17 12:10 AM
Albany, NY
Albany, NY
Guys, thanks so much,
Those are excellent ideas to try - I've got an infrared temp gun and I'll see what it tells me, shut-off valve isn't mentioned in the FSM, but I'll look closely at all the plumbing - and I'll go ahead with the flush too in the morning.
- Art
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2371986
09/17/17 12:15 AM
09/17/17 12:15 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
If you have a heater only there is no shut off valve. Only a hot cold blend door in the heater box.
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: NANKET] #2371992
09/17/17 12:22 AM
09/17/17 12:22 AM
Albany, NY
Albany, NY
Originally Posted By NANKET
... there is no shut off valve. Only a hot cold blend door in the heater box.
Thanks, .. yes this is what my FSM shows, and AFAIK the blend door works cuz the lever arm moves freely and I can hear the door inside sort of slam against its stops when I operate the cold/hot selector lever.. and it's a very original car ...but ya never know if a PO could have rigged something weird, I'll check for it anyway..
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2372178
09/17/17 01:37 PM
09/17/17 01:37 PM
central il.
second 70 Offline
second 70  Offline
central il.
I had an old chevy when I was young that we all thought was just cold blooded and had a poor heater. Tried the 1970's fix of cardboard in front of radiator and it still sucked.
Finally one day I decided to flush the core out with a garden hose. Took both hoses of engine an just hit it with moderate pressure every so often till it flowed freely. And what do you know I ended up with a heater that would melt snow of the car.
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2372205
09/17/17 02:14 PM
09/17/17 02:14 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
There isn't a heater control valve on this? Only later model cars had a HCV (water)?
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: Dave Hall] #2372242
09/17/17 03:19 PM
09/17/17 03:19 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
66-70 B-body Heater control valve only with factory A/C system. Standard heat has no heater vavle in the supply line.
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2372469
09/18/17 12:30 AM
09/18/17 12:30 AM
Albany, NY
Albany, NY
Whatever is wrong must be pretty simple or basic. There are so few moving parts to this setup.
Got to spend a little time on this today:
- Checked coolant and it looks very clean, no crud.
- At engine start the water pump housing rose to 125F within 5-10 minutes, but both supply and return hoses from the water pump remained at 80F. I started wondering if I could have a blocked hose, or blocked nipple at the water pump - then I noticed there was a rattle sound from the water pump, so maybe an impeller problem?
- Took it for a drive and got it up to temperature: Forgot to try it in Defrost mode, but switching from Heat to Cold I got no change in air temperature.
- The blower motor works, and I get decent airflow out of the air outlet pointed at my feet.
- Back at the garage, I kept engine running at idle and measured 185-188F at the water pump housing. At the firewall, the driver's side hose measured 156F (inlet), the passenger side hose measured 114F(outlet) - so there must be flow thru the core. I forgot to notice if I still had the rattle sound from the water pump.
This seems like a functional core, but there is no harm flushing it, plus the hoses and nipples tomorrow. Maybe airflow thru the core is the problem, like the fins are clogged with lint or something, but that's internal to the airbox, so last ditch effort only.
I'll keep looking and fiddling with it.
- Art
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2372598
09/18/17 10:48 AM
09/18/17 10:48 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Just flush the core and be done with it. You are most likely reading heat conducted back from the engine thru the coolant to the output side of the heater core. 114 degrees is nothing really, especially since you are getting no heat removal thru the heater, were did the 40 degree difference go?
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: Supercuda] #2372689
09/18/17 01:22 PM
09/18/17 01:22 PM
Albany, NY
Albany, NY
1.) Thx. Will do.
2.) I have no @^#% idea. Agree, 40F is a big diff. It's not coming into the cabin. There is normally always hot coolant flow thru the core though, because there is no hot-coolant-shut-off-valve in the plumbing, only a damper/door that directs airflow from the core.
Thanks, I'll get into it after I get the NYS Inspection done today.
- Art
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2372698
09/18/17 01:31 PM
09/18/17 01:31 PM
central il.
second 70 Offline
second 70  Offline
central il.
Don't be surprised if the nipples on the block are partially clogged. Just clean them out and you're good to go.
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: second 70] #2372815
09/18/17 04:35 PM
09/18/17 04:35 PM
Albany, NY
Albany, NY
Yeah, I was thinking this is possible with corrosion at the metal nipples, the water pump and t'stat housings are already kinda cruddy... if the crap gets dislodged and then caught in the core.. and it won't show up in the radiator cuz it's all stuck in the core..
..today I'm waiting for my local gas station to finish a State Safety Inspection on it before I get further into this..
Cheers, - Art
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2372852
09/18/17 05:33 PM
09/18/17 05:33 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I also had a 60's Mop with no heat. I flushed the core at the nipples of the core- and filled the interior with water.
Pull the hoses at the water pump as suggested above to prevent the same screwup I had.
On the plus side the heater worked great afterward.
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: dynorad] #2373724
09/20/17 01:33 AM
09/20/17 01:33 AM
Albany, NY
Albany, NY
Flushed the heater core and got heat.
Took 15 minutes. Tapped a gallon or so of coolant from the radiator spigot. Unclamped the coolant hoses at the firewall nipples and flushed garden hose water thru backwards (flush water went in the passenger side nipple). Some milky crud came out but not much. Ran water til it all came out clear.
Then I decided to flush the whole system, removed the radiator cap and ran hose water thru the same heater hoses to the water pump and let it clear out. Refilled w glycol.
...no water on my carpet..
Originally Posted By dynorad
...On the plus side the heater worked great afterward.
smile smile
Thanks all.
- Art
Re: 1967 B-body No heat from heater... checked FSM. Any ideas? [Re: 67SATisfaction] #2373778
09/20/17 05:29 AM
09/20/17 05:29 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Glad it was easy and you posted the results!
