T handle valve cover nuts backing out #2371751
09/16/17 03:55 PM
09/16/17 03:55 PM
Rancho Cordova, Calif.
davidcwhitney Offline OP
I got my fancy Mopar Performance valve covers and a set of T handles. I'm not sure I set the studs properly. When I start the engine the vibration makes the assembly come loose.
I put the studs in finger tight. I am afraid to bear down with the T handles because I don't want to ruin my valve covers. Is there a "torque spec" to tell me when to stop?
I am not wedded to the T handles, they are for convenience of installation (motor home, beats crawling around underneath to get the outboard ones). If I junk them, what's the best bolt option for a 1976 440 with 452 heads and Mopar Performance valve covers?
Thanks.
1977 Executive Diplomat II
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2371756
09/16/17 04:01 PM
09/16/17 04:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I had a set of those a long while back.
They had lock washers.
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2371774
09/16/17 04:51 PM
09/16/17 04:51 PM
Hmmm these did not come with washers, that's one of the reason's I'm concerned about ruining the covers. I'll consider testing that.
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2371788
09/16/17 05:33 PM
09/16/17 05:33 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I have some of those on my B engine Barracuda, ended up using the Moroso gaskets and buying 2 sets of the Summit Chevy load spreaders- the triangular shaped ones. So far so good. twocents
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2371829
09/16/17 07:28 PM
09/16/17 07:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Use a flat washer AND a lock washer.
Don't be the exception.
Re: T handle valve cover nuts backing out [Re: Supercuda] #2371895
09/16/17 10:06 PM
09/16/17 10:06 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
I had some on my 800 hp wedge and on the dyno we watched them spin counterclock wise at higher rpms. It was harmonics
The little old lady from Pasadena is back!
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2371897
09/16/17 10:18 PM
09/16/17 10:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks.
I'd try lock tite, blue and maybe a lock washer? Might have room for a washer if you try a AN washer which is smaller than a reg washer. That would help protect the valve cover from the lock washer.
Make sure the valve cover are not interfering with the intake manifold too.
Re: T handle valve cover nuts backing out [Re: Challenger 1] #2372005
09/17/17 12:43 AM
09/17/17 12:43 AM
Loctite on the stud threads into the head and the exposed threads?
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2372116
09/17/17 10:50 AM
09/17/17 10:50 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Basrnstorm is correct on the harmonics, just too much mass far away from the contact area to control with the engine vibration variations.
Joe
Re: T handle valve cover nuts backing out [Re: Supercuda] #2372203
09/17/17 02:13 PM
09/17/17 02:13 PM
iagree
I always use a AN size flat washer under any bolt head I use on aluminum parts, unless the bolt has a flange built into it, to prevent wear, digging into the part and marking up the aluminum scope
I can't remember using a lock washer on any but why not work
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2372210
09/17/17 02:23 PM
09/17/17 02:23 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I wouldn't worry about bearing down on them if they are cast covers. I go as far as I can go with a 1/4" drive driver handle. I actually use a 1/4" drive ratchet but I don't lever the handle. In other words I keep the ratchet part in the palm of my hand and go until they stop.
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2372375
09/17/17 08:59 PM
09/17/17 08:59 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
I had some of those things and never could keep them tight. I trough them in the trash can and moved on.
Re: T handle valve cover nuts backing out [Re: davidcwhitney] #2372384
09/17/17 09:19 PM
09/17/17 09:19 PM
Cincinnati, Ohio
Cincinnati, Ohio
yes and yes.
Re: T handle valve cover nuts backing out [Re: Challenger 1] #2372634
09/18/17 11:46 AM
09/18/17 11:46 AM
moparx Offline
moparx  Offline
i have used common O-rings at times to keep fasteners from backing out from vibrations. just pick a size that "screws" onto the thread in question. the resistance from the material keeps the fastener from backing out. high temperature material would be my choice for this particular application, but i can't tell you what this material is. possibly AC O-ring material ?
beer
