Re: BB distributor lock collar... Does this look right?
[Re: JoesMopar]
#2371755
09/16/17 03:59 PM
09/16/17 03:59 PM
Posts: 2,782 USA
JoesMopar
USA
[Re: JoesMopar]
#2371799
09/16/17 06:02 PM
09/16/17 06:02 PM
RapidRobert
first I would drive out the roll pin in the plastic collar & add flat shims (speedway has a kit for $10) to reduce the axial clearance to .005". Yes blue loctite & I'm assuming you put the collar on snug then set the dist in place down in there to set the height then carefully removed the dist then tightened up the setscrew.
[Re: a12rag]
#2371879
09/16/17 09:14 PM
09/16/17 09:14 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Always thought the lock collar went up against the body of distributor so the shaft would not move up & down . . . usually there is a spot there for the roll pin to go through the distributor shaft . . . the gear won't move, as the distributor is held down on with the upper outside collar . . . The dist shaft does not bottom out on the oil pump shaft, there is a lot of clearance there for the oil pump shaft to move up & down,, & it does,,fixed many of them with the lock collar like the OP. is doing. before, timing light jumps all over,, after, nice & steady
[Re: JoesMopar]
#2371892
09/16/17 09:56 PM
09/16/17 09:56 PM
Posts: 257 Alberta
440_Offroader
Alberta
I may be wrong, but I thought 'the bouncing timing thing' was a small block issue,due to the cw rotation. I've never had any of my big blocks have their timing bouncing around. My 360 definitely has the timing fluctuations (which I need to fix someday). Maybe I've just been lucky with my big blocks?
[Re: 440_Offroader]
#2371938
09/16/17 11:18 PM
09/16/17 11:18 PM
CSK
Pattison Texas
I may be wrong, but I thought 'the bouncing timing thing' was a small block issue,due to the cw rotation. I've never had any of my big blocks have their timing bouncing around. My 360 definitely has the timing fluctuations (which I need to fix someday). Maybe I've just been lucky with my big blocks? Mine is a big block, & it did jump around, clock,or counter direction has no bearing on timing fluctuation.
[Re: CSK]
#2372037
09/17/17 01:46 AM
09/17/17 01:46 AM
Posts: 257 Alberta
440_Offroader
Alberta
[Re: JoesMopar]
#2372218
09/17/17 02:39 PM
09/17/17 02:39 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I filled the drive gear slot with a leather piece, which should make the same job adding a cushion as a plus, and still have the jumping timming at iddle
[Re: NachoRT74]
#2372223
09/17/17 02:50 PM
09/17/17 02:50 PM
RapidRobert
Happy birthday Nacho. I'm gonna kick back & watch some pro FOOTBALL today, (we don't do hand eggs). OP the main problem with it is alot of slop makes for spark scatter when timing it at idle as does slop in the timing chain. You're right when "loaded" when accellerating all the play is taken out but steady speed or letting off the gas it can & will fluctuate. Maybe not a dealbreaker but the builder who goes to the nth degree in all areas will be the one that gets to kiss the trophy girl.
[Re: JoesMopar]
#2372660
09/18/17 12:27 PM
09/18/17 12:27 PM
NachoRT74
Valencia, España
Thanks Robert, my Good friend!!! LOL. I was hearing the real football from Spanish league on the radio.
I do ( or did ) have the same problem... fit the leather piece into the slot which actually makes the same than the lock ring and still have the same jumping timming at iddle maybe +/- 2°or 3°. I wouldn't state that as a problem if just at iddle, because of course giving gas should be tight due the gears being loaded, however I would like to get a steady reading at iddle.
My car is toptally dissasembled anyway... will take care of that I hope next month.
allways read this kind of threads just on case I find something new.
