68 340 timing marks #237143
02/26/09 05:32 PM
02/26/09 05:32 PM
NW Indiana
deansrr Offline OP
deansrr  Offline OP
NW Indiana
have a 68 340 and doesn't have timing marks on timing cover, how did they check timing on these models? is there a timing tab out there that someone makes?
thanks
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: 68 340 timing marks [Re: deansrr] #237144
02/26/09 05:46 PM
02/26/09 05:46 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
The earlier ones had a bolt on tab that was on the passenger side, the later had it made to the cover and was on the drivers side. Someone had yours off and didnt put it back.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: 68 340 timing marks [Re: 70dart360] #237145
02/26/09 06:36 PM
02/26/09 06:36 PM
NW Indiana
deansrr Offline OP
deansrr  Offline OP
NW Indiana
my engine came in pieces, do you know anyone that has these tabs?
Re: 68 340 timing marks [Re: 70dart360] #237146
02/26/09 06:37 PM
02/26/09 06:37 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Correct. The odd ball is the '69 timing chain cover. That was a one year cover that had the marks cast into the passenger's side.
I recently bought a '68 and earlier "timing pointer" so I could use a '70 and up timing chain cover and still set the timing from the passenger's side.
Re: 68 340 timing marks [Re: deansrr] #237147
02/26/09 06:39 PM
02/26/09 06:39 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
They aren't reproduced. You have to find one used. I put a wanted ad up here and got some responses. All the small blocks from '64-'68 had them so used ones can be found.
Re: 68 340 timing marks [Re: 69Cuda340S] #237148
02/26/09 06:42 PM
02/26/09 06:42 PM
NW Indiana
deansrr Offline OP
deansrr  Offline OP
NW Indiana
thanks, i'l keep looking
Re: 68 340 timing marks [Re: 69Cuda340S] #237149
02/26/09 07:25 PM
02/26/09 07:25 PM
why did you use the later tcover? were you using an early wp w dr side hose & wanted to time it without having to deal with that interference & also did you use an early harmonic dampener or remark a 70 & up one?
Re: 68 340 timing marks [Re: RapidRobert] #237150
02/27/09 11:19 AM
02/27/09 11:19 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I wanted to keep my original numbers matching 340 complete so I didn't want to take the cover off that engine. I bought a '71 340 block and built a stroker out of it. That came with a '71 340 timing chain cover. Then I bought a Mopar Performance vibration damper which has the '70 and up marks. But I run the '69 water pump and could not see the marks. So I re-indexed the damper and put another timing tape on it and use the timing pointer. Now I time it from the passenger's side where nothing blocks the marks. Here is the timing pointer I bought installed:
Re: 68 340 timing marks [Re: 69Cuda340S] #237151
02/27/09 12:04 PM
02/27/09 12:04 PM
Yeah, and 318 poly's too.
Re: 68 340 timing marks #237152
02/27/09 04:55 PM
02/27/09 04:55 PM
Why not just build your own pointer? You can do as 69340 Cuda and but the proper timing tape (it must match the damper diameter) and then build a pointer. Alternately, you can calculate how many degrees per inch on your damper (it's easy) and scribe the damper every 5 deg or so. Setting up TDC is easy Just build yourself a "positive stop" from an old sparkplug--or buy one. You screw the stop into no1 plug hole, and wrench the engine around 'til it stops. Temporarily mark the damper under the pointer--that you have built--and then turn the engine around CCW untils it stops, and AGAIN mark the damper under the pointer. EXACTLY halfway between the two marks on the damper is TDC. then all you have to do is either install your timing tape, or scribe the damper and you are not only done--but now you know the marks are correct.
Bear in mind the pointer you build doesn't have to be a tab or have any numbers---just a sharp pointer to index in reference to the damper. It doesn't matte where you put it--so put it where you can SEE it. Then build the TDC and other marks onto the damper to suit.
Re: 68 340 timing marks #237153
02/27/09 05:56 PM
02/27/09 05:56 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: 68 340 timing marks [Re: 70AARcuda] #237154
02/27/09 06:07 PM
02/27/09 06:07 PM
NW Indiana
deansrr Offline OP
deansrr  Offline OP
NW Indiana
thanks for everyone's imput
Re: 68 340 timing marks [Re: 69Cuda340S] #237155
02/27/09 07:18 PM
02/27/09 07:18 PM
Thank you, now I understand.
Re: 68 340 timing marks [Re: 70AARcuda] #237156
02/28/09 04:44 PM
02/28/09 04:44 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
here ya go...
http://cgi.ebay.com/ebaymotors/MOPAR-DOD...sspagenameZWDVW
No way that cover is from a 68, It has the timing numbers cast into the case.
Re: 68 340 timing marks [Re: formula_s] #237157
02/28/09 06:04 PM
02/28/09 06:04 PM
The seller is mistaking the 68 casting year # on the tcover with it's actual 69 model year usage
Re: 68 340 timing marks [Re: RapidRobert] #237158
02/28/09 09:42 PM
02/28/09 09:42 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Yeah that is a '69 small block timing cover.
Re: 68 340 timing marks #237159
02/28/09 09:43 PM
02/28/09 09:43 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I bought mine for $15 including shipping. Not worth my time to make one myself.
Re: 68 340 timing marks [Re: 69Cuda340S] #237160
03/01/09 08:51 AM
03/01/09 08:51 AM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
1970 Duster 340 clone
Re: 68 340 timing marks [Re: formula_s] #237161
03/01/09 10:19 PM
03/01/09 10:19 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
here ya go...
The numbers matching 318 from my '68 B'cuda has the cast style '69 timing cover. I can't be certain it is original to the motor, but it is not a common item to fail in service. I guess the real question is when in '68 did the '69 cover come into service? My '69 340 GTS with a 9/68 build date has the cast timing marks...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 68 340 timing marks [Re: deansrr] #237162
03/01/09 10:41 PM
03/01/09 10:41 PM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
I have an early build (8/01/68) 69 Dart GTS. The timing marks cast in on the passenger side of the timing cover would be correct for my early build 69 Dart GTS with the 340. I'm actually watching that one mentioned above on Egag.
Also...the lower piping on the 68-69 340 water pump goes to the drivers side not the passenger side.
So, in this Egag auction it has a correct 68-69 340 water pump, but an incorrect 68-69 340 timing cover. If the timing marks are on the same side as your lower hose it might be hard to see.
Egag water pump & timing cover
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
