68 340 timing marks
#237143
02/26/09 05:32 PM
02/26/09 05:32 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
have a 68 340 and doesn't have timing marks on timing cover, how did they check timing on these models? is there a timing tab out there that someone makes? thanks
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
Re: 68 340 timing marks
[Re: deansrr]
#237144
02/26/09 05:46 PM
02/26/09 05:46 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
The earlier ones had a bolt on tab that was on the passenger side, the later had it made to the cover and was on the drivers side. Someone had yours off and didnt put it back.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 70dart360]
#237145
02/26/09 06:36 PM
02/26/09 06:36 PM
deansrr
NW Indiana
my engine came in pieces, do you know anyone that has these tabs?
1973 Road Runner
1973 240z (wifes)
2002 Honda S2000
[Re: 70dart360]
#237146
02/26/09 06:37 PM
02/26/09 06:37 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Correct. The odd ball is the '69 timing chain cover. That was a one year cover that had the marks cast into the passenger's side.
I recently bought a '68 and earlier "timing pointer" so I could use a '70 and up timing chain cover and still set the timing from the passenger's side.
[Re: deansrr]
#237147
02/26/09 06:39 PM
02/26/09 06:39 PM
69Cuda340S
MARYLAND
They aren't reproduced. You have to find one used. I put a wanted ad up here and got some responses. All the small blocks from '64-'68 had them so used ones can be found.
[Re: RapidRobert]
#237150
02/27/09 11:19 AM
02/27/09 11:19 AM
69Cuda340S
MARYLAND
why did you use the later tcover? were you using an early wp w dr side hose & wanted to time it without having to deal with that interference & also did you use an early harmonic dampener or remark a 70 & up one?
I wanted to keep my original numbers matching 340 complete so I didn't want to take the cover off that engine. I bought a '71 340 block and built a stroker out of it. That came with a '71 340 timing chain cover. Then I bought a Mopar Performance vibration damper which has the '70 and up marks. But I run the '69 water pump and could not see the marks. So I re-indexed the damper and put another timing tape on it and use the timing pointer. Now I time it from the passenger's side where nothing blocks the marks. Here is the timing pointer I bought installed:
[Re: 69Cuda340S]
#237151
02/27/09 12:04 PM
02/27/09 12:04 PM
Yeah, and 318 poly's too.
#237152
02/27/09 04:55 PM
02/27/09 04:55 PM
Why not just build your own pointer? You can do as 69340 Cuda and but the proper timing tape (it must match the damper diameter) and then build a pointer. Alternately, you can calculate how many degrees per inch on your damper (it's easy) and scribe the damper every 5 deg or so. Setting up TDC is easy Just build yourself a "positive stop" from an old sparkplug--or buy one. You screw the stop into no1 plug hole, and wrench the engine around 'til it stops. Temporarily mark the damper under the pointer--that you have built--and then turn the engine around CCW untils it stops, and AGAIN mark the damper under the pointer. EXACTLY halfway between the two marks on the damper is TDC. then all you have to do is either install your timing tape, or scribe the damper and you are not only done--but now you know the marks are correct.
Bear in mind the pointer you build doesn't have to be a tab or have any numbers---just a sharp pointer to index in reference to the damper. It doesn't matte where you put it--so put it where you can SEE it. Then build the TDC and other marks onto the damper to suit.
[Re: formula_s]
#237157
02/28/09 06:04 PM
02/28/09 06:04 PM
RapidRobert
The seller is mistaking the 68 casting year # on the tcover with it's actual 69 model year usage
#237159
02/28/09 09:43 PM
02/28/09 09:43 PM
69Cuda340S
MARYLAND
I bought mine for $15 including shipping. Not worth my time to make one myself.
[Re: deansrr]
#237162
03/01/09 10:41 PM
03/01/09 10:41 PM
Posts: 1,592 Mansfield, TEXAS
JOES4FORTY
Mansfield, TEXAS
I have an early build (8/01/68) 69 Dart GTS. The timing marks cast in on the passenger side of the timing cover would be correct for my early build 69 Dart GTS with the 340. I'm actually watching that one mentioned above on Egag. Also...the lower piping on the 68-69 340 water pump goes to the drivers side not the passenger side. So, in this Egag auction it has a correct 68-69 340 water pump, but an incorrect 68-69 340 timing cover. If the timing marks are on the same side as your lower hose it might be hard to see. Egag water pump & timing cover
The GTS Registry!MOPARTS MEMBER IN PRINT 1969 Dart GTS LS23P9B (First day of production car money pit)
