E-85 Update #23711
04/13/06 09:32 PM
04/13/06 09:32 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
Well I've heard the naysayers and the doom and gloomers talk about all the bad aspects of running E-85. I've had people tell me it will corrode aluminum, ruin rubber fuel lines, eat plastic, eat carburetors alive.
After hearing all these predictions I decided to put it to the test. Last Sept. I drove my truck down to Interstate Dragways to see Don1 and JericoGTX. After I got home that night I parked the truck in the garage. That was the last time it was started or run until tonite. It had a 3/4 full tank of E-85 in it. I shut the electric fuel pump off and let the engine run until it died. The rear float bowl was almost full, I didn't touch anything, I didn't even open the hood until tonite.
I went out to the garage tonite, opened the hood, pulled the aircleaner. As I always do after sitting all winter, I started the fuel pump and let the carb fill and made sure the floats weren't stuck before hitting the key. I checked the accelerator pumps and found the rear one wasn't pushing fuel out the squirters. I pulled the rear bowl and metering block off along with the rear squirter. Everything looked as good as the day I screwed it together last summer. The needle under the squirter was stuck and a shot of carb cleaner in a can fixed that. I put everything back together let the carb fill and hit the key. The engine started instantly and ran as sharp as it did the last time I drove it in Sept.
The plastic fuel cell, 3/8" aluminum fuel line, no name electric fuel pump, rubber fuel line, inline fuel filter, and carb look and work as good as they did in Sept.
So much for the naysayers and the rest that said it wouldn't work. The only down side I can see is that the 105-110 octane E-85 is now only $.30 under 89.5 octane regular at my local station.Dave
Re: E-85 Update [Re: quickd100] #23712
04/13/06 09:55 PM
04/13/06 09:55 PM
Kansas wishing I was in Ohio
SeanD Offline
SeanD  Offline
Just out of curiosity, what kind of mileage are you getting? Better, worse or same.
Re: E-85 Update [Re: quickd100] #23713
04/14/06 05:48 AM
04/14/06 05:48 AM
gregsdart Online content
gregsdart  Online Content
Dave, nice to hear it is working for you. It is great to read storys about others that think outside the box a bit, and can engineer something to success. Good job! What power differance have you seen and how much compression do you run? I would think a motor built with optimum compression for E85 would reduce the loss of mileage some?
Re: E-85 Update [Re: gregsdart] #23714
04/14/06 06:18 AM
04/14/06 06:18 AM
nielsville, minn.
Q
Q
nielsville, minn.
Greg; I'm running 11.2-1, I'd like to have had 12.5-13-1. The motor was junk off the garage floor and I didn't want to spend any money on it. 11.2-1 was as much as I safey dared squeeze it without having valves poking holes in the pistons.
As far as mileage goes, the last time I drove it going to the strip I was bucking a 25 mph headwind on the way down there. My mileage was 9.5 mpg, 1 mpg less than the last time I checked it on gasoline. I think it is probably as good or better than when the motor was on gasoline. I do believe most of the mileage issue can be made up by bumping the compression up as high as possible. Another point, I'm running it quite a bit on the rich side, for max power, I could lean the mixture down about 7%.
I haven't run it at the strip on E-85 but it feels as strong, or stronger on E-85 than it did on gasoline. Here's an example;
Last fall my brother and a buddy of his stopped by one Sunday. I was tuning on the carb. They decided I should take them for a ride. So the 3 of us piled into the truck, (650lbs.) I had the street tires and full exhaust on and the caltracks. We went east on a good hooking new asphalt road. I stood on it at 40-45mph. The rearend started to come around on me, we were at a 45 degree angle before it finally hooked up again. On gasoline it never did that before at least not at 80 degree temps.Dave
Re: E-85 Update [Re: quickd100] #23715
04/14/06 06:30 AM
04/14/06 06:30 AM
Sounds like fun to me !!
Re: E-85 Update [Re: gregsdart] #23716
04/14/06 08:10 AM
04/14/06 08:10 AM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
That 15% gasoline is enough to prevent the white chalk and the drying out of rubber and plastics that 100% alcohol does. You also have to remember our cousins in south central and south america have been running straight alcohol for years.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: E-85 Update [Re: quickd100] #23717
04/14/06 08:19 AM
04/14/06 08:19 AM
NC
440Jim Offline
440Jim  Offline
NC
That's good news.
I need to learn more about the differences between methanol (race alcohol) and ethanol (drinking alcohol) used in E-85. Did you have to richen the carb jets when converting from straight gasoline?
Maybe this will be the bracket racing fuel of choice in the future?
Re: E-85 Update [Re: Slingshot383] #23718
04/14/06 08:20 AM
04/14/06 08:20 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Dave has spent a lot of time working oon this truck and getting the thing set up to run on the E85. I think that most of the horror stories on parts deterioration from the use of alcohol blended gasolines comes from back when they were first introduced in the 70'ss when vehicle components were not yet compatable with alcohol. Garentee yo that if you put a blended gas or E85 in an older steel gas tank you will have big time problems. It will clean out eery bit of rust and crap in teh system. And that is just what happened back them before plastic tanks were the normal thing.
Dave are you fighting water or are you high and dry?
Re: E-85 Update [Re: MoparforLife] #23719
04/14/06 07:23 PM
04/14/06 07:23 PM
nielsville, minn.
Q
Q
nielsville, minn.
Don; I'm high and dry but it's a headache getting to work as the shop is on the wrong side of the river. I'm hoping I'll be able to get across by Sunday or Monday.
Don, how are you doing? Are you getting over the pneumonia?
Jim; You have to richen EVERY curcuit by 27-35%. I went 35% to keep it safe. I think E-85 would make a wonderful replacement for race gas. You can keep your compression, it runs cooler, and it's CHEAP. Did I mention it's CHEAP? When is the last time you bought 110 octane gas for $2.00? When is the last time you could go down to the corner gas station and buy 110 octane fuel cheaper than regular? Dave
Re: E-85 Update [Re: quickd100] #23720
04/14/06 09:37 PM
04/14/06 09:37 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know much about methanol either, but it sounds like methanol needs richer than ethanol. It might make sense to start with an alcohol (methanol) carb, and lean it out? Or is methanol more like 100% richer?
I have never seen E85 in Maryland, never mind in my remote section of the state.
Re: E-85 Update [Re: 440Jim] #23721
04/14/06 09:52 PM
04/14/06 09:52 PM
Illinois
493_Scamp Offline
super gas
493_Scamp  Offline
super gas
Illinois
I plan on running E85 in my nearly done 493. I am going to buy a Proform 950 to modify because it is the cheapest carb of that size and some mods would be nonreversable. I should have the motor running in a couple weeks.E85 is $2.29 here.
Re: E-85 Update [Re: 493_Scamp] #23722
04/14/06 09:59 PM
04/14/06 09:59 PM
nielsville, minn.
Q
Q
nielsville, minn.
Before you start hacking on your holley, take a look at the June 2006 Mopar muscle mag page 74. Quick Fuel Technology offers billet metering blocks with screw in idle feed restrictions,and changeable power valve channel restrictions. Both of which you will have to alter to run E-85. Dave
Post deleted by Defbob [Re: 493_Scamp] #23723
04/14/06 10:00 PM
04/14/06 10:00 PM
Re: E-85 Update #23724
04/15/06 06:19 AM
04/15/06 06:19 AM
nielsville, minn.
Q
Q
nielsville, minn.
Dave; I would sure think so, I'd bet that lil' blown hemi would really like the stuff . Is it get'n warm down there yet? It was 76 degrees here yesterday. Dave
Re: E-85 Update [Re: quickd100] #23725
04/15/06 07:00 AM
04/15/06 07:00 AM
One thing to remember, all the bad juju is taken from those running methanol. It is NOT the same as ethanol which is far less corrosive.
Re: E-85 Update #23726
04/15/06 08:08 AM
04/15/06 08:08 AM
Portage Wisconsin
Lou_Steger Offline
Lou_Steger  Offline
Portage Wisconsin
So once you get a car to run on E-85 does it take major changes to run gasoline?
Re: E-85 Update [Re: Lou_Steger] #23727
04/15/06 09:43 AM
04/15/06 09:43 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'm interested in the stuff, but so far around here the prices are higher than premium gas.
here's a site that has a station-finder: www.e85fuel.com
Re: E-85 Update [Re: Lou_Steger] #23728
04/15/06 01:44 PM
04/15/06 01:44 PM
nielsville, minn.
Q
Q
nielsville, minn.
Lou S.; The easiest way to switch back to gasoline would be to have a separate carb for gasoline. Just switch carbs and drain the tank of E-85 and fill it with gasoline. Dave
Re: E-85 Update [Re: quickd100] #23729
04/15/06 01:56 PM
04/15/06 01:56 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Humm this is interesting. My question is this, what kind of changes should I do to run it in my Coronet? 440 engine 750 edelbrock carb, headers stock everything else engine wise.
Mike
1969 Dodge Dart Swinger
Re: E-85 Update [Re: MikeyT] #23730
04/15/06 06:25 PM
04/15/06 06:25 PM
440JIM, the ratio for methonal is 2.2 times that of gasoline, or about double that of ethanol or E85.
