Re: Question on ballast resistor failing
[Re: Dixie]
#2371400
09/15/17 08:37 PM
09/15/17 08:37 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Ballasts are bypassed in start
I'm thinking loose connetion that got "jiggled" when you jumpered it
[Re: Dixie]
#2371528
09/16/17 12:26 AM
09/16/17 12:26 AM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
I had one years ago go bad on my '71 Charger. It was intermittent. It's such a cheap part, just replace it & see if the problem is solved.
[Re: Sunroofcuda]
#2371581
09/16/17 02:38 AM
09/16/17 02:38 AM
RapidRobert
next time it wont start, pull the yellow wire off of the "ign" terminal to disable the starter & have a helper hold the key to "crank" & you with your meter or a test light see if the coil positive primary terminal & the blue/yellow ECU terminal are being fed & work upstream from them to find the open. In the meantime as said I would clean/wiggle all pertinent connections/terminals starting with the ballast & pull & put back in place the bulkhead which alot of times is enough to restore continuity there. short version: if all you touched/wiggled is the ballast then as said check its terminal connections & replace it. EDIT In fact what I think I would do is bypass it & see if it will start a half dozen times right in a row & dont let it run more than several seconds each time.
