Tricky Dent..... #237127
02/26/09 05:14 PM
02/26/09 05:14 PM
Martin TN
ridin98ci Offline OP
Martin TN
OK....I have a question for you body guys.....I have a 74 Coronet that the roof was pushed in on....I popped most all of it out but there is still about a 10 inch round dent that I cant get to pop out.....what can I do?
LOUD AND PROUD!!!
Re: Tricky Dent..... [Re: ridin98ci] #237128
02/26/09 05:18 PM
02/26/09 05:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried a old fashion rubber toilet plunger?
Re: Tricky Dent..... [Re: stumpy] #237129
02/26/09 05:23 PM
02/26/09 05:23 PM
Martin TN
Martin TN
Yeah I have....I cant get the rest of it up. I even dropped the headliner and pushed it up and it popped right back down....I am getting kinda pissed...
LOUD AND PROUD!!!
Re: Tricky Dent..... [Re: ridin98ci] #237130
02/26/09 05:40 PM
02/26/09 05:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The metal has been stretched & needs to be shrunk...They are numerous ways of doing that, shrinking hammer, heat & quench, grinding disc & quench...
Rather than typing for the next hour I did a quick search...Here ya go..
http://www.autobodystore.com/forum/archive/index.php/t-157.html
Re: Tricky Dent..... [Re: ridin98ci] #237131
02/26/09 05:43 PM
02/26/09 05:43 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
How bout adding a Sunroof?
Sorry, not much help.
Years ago the garage door came down hard on the rear quarters of my 70 RR. My body guy didn't even blink at it. With a torch and light taps of a hammer it was good as new.
Good luck.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Tricky Dent..... [Re: 1_WILD_RT] #237132
02/26/09 05:43 PM
02/26/09 05:43 PM
Martin TN
Martin TN
How hard is it to F the procedure up? I am no body man....
LOUD AND PROUD!!!
Re: Tricky Dent..... [Re: 1_WILD_RT] #237133
02/26/09 05:44 PM
02/26/09 05:44 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
heat & quench
Re: Tricky Dent..... [Re: ridin98ci] #237134
02/26/09 05:44 PM
02/26/09 05:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I edited my post...
Re: Tricky Dent..... [Re: 1_WILD_RT] #237135
02/26/09 05:57 PM
02/26/09 05:57 PM
Martin TN
Martin TN
OK so does the shrinking wheel work as well as the torch? do you work from the outside in or vice verse?
LOUD AND PROUD!!!
Re: Tricky Dent..... [Re: ridin98ci] #237136
02/26/09 06:37 PM
02/26/09 06:37 PM
Martin TN
Martin TN
Here is what I am dealing with....it is just my driver but I hate that dang dent...
LOUD AND PROUD!!!
Re: Tricky Dent..... [Re: ridin98ci] #237137
02/26/09 07:04 PM
02/26/09 07:04 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
It can be easy to mess up if you heat it too much. Leave it to a pro if you're not sure.
Re: Tricky Dent..... [Re: In_The_Pink] #237138
02/26/09 07:29 PM
02/26/09 07:29 PM
qc
mxbeep Offline
mxbeep  Offline
qc
try to locate a paintless dent remover in your area.
They patiently remove dents without re-painting,
I would suggest talking with a body shop owner in your area, they often deal with these paintless dent removers.
Unless you have the skills, dont try to repair your roof , chances are you will make it much worst
Re: Tricky Dent..... [Re: mxbeep] #237139
02/26/09 08:34 PM
02/26/09 08:34 PM
Martin TN
Martin TN
Thanks for all the input guys....I think I will see if one of the shops around here will mess with it.
LOUD AND PROUD!!!
Re: Tricky Dent..... [Re: ridin98ci] #237140
02/26/09 09:09 PM
02/26/09 09:09 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
If it was me, I would mix up some bondo and apply it to the inside of the roof with the dent popped up. It will need to be at least 1/4 inch thick. Once the bondo hardens it will stay up. This way there is no damage to the exterior paint work. Replace the headliner and know one will know.....Phill
Re: Tricky Dent..... [Re: 9 Sec Phill] #237141
02/26/09 09:34 PM
02/26/09 09:34 PM
qc
mxbeep Offline
mxbeep  Offline
qc
and always drive around with a helmet for when the bondo comes apart and falls on your head
Re: Tricky Dent..... [Re: ridin98ci] #237142
02/26/09 10:54 PM
02/26/09 10:54 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Way back a guy I knew used dry ice to pop a large dent. Put the ice on and covered it with a towel, its cheap and most market carry it, $1.00 to 1.50 a pound.
