Shortening pushrods....looking for advice 1st timer #2370527
09/14/17 03:08 AM
09/14/17 03:08 AM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
I've got a set of pushrods that are too long....they are good Manton ones w removable ends, and they can be safely shortened upto .015....I've recently ordered a 12 inch dial caliper and gotten a ball bearing....to accurately measure them. I understand if I heat up the end of a pushrod tube, the end should pull out reasonably easily, then I was thinking I could chuck them in my drill press and push down against a grinding stone to shorten them. Does this sound like a workable plan? Any suggested ways to do it better? Does it matter which end I do this to?
Thanks for any and all help
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370538
09/14/17 04:24 AM
09/14/17 04:24 AM
I think I was told by Manton employees that they could shorten most of there race pushrods up to .150, no more work
Call them for advice first twocents
Don't heat the ends up until you know your safe doing that tsk twocents
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370541
09/14/17 05:02 AM
09/14/17 05:02 AM
CA
62SAVOY Offline
62SAVOY  Offline
CA
Also depends on how hard the pushrod tubes are. The CompCams ones I am making to length are hard. Also because of them being a thick wall tube size. I have to drill them out in the lathe for the cup to press in once shortened.
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370564
09/14/17 09:19 AM
09/14/17 09:19 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
There was a thread on this topic some time ago ... take a look at: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2248608/1.html for some sage advice.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370707
09/14/17 01:45 PM
09/14/17 01:45 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I used to buy pushrod kits from mancinni and build all my own push rods, but the quality of the kits went south so I stopped buying them. The main issue is the inside diameter of the push rod and getting the proper press fit. Most of the tubes have to be reamed to get the proper fit. Use a lathe or be very careful with a die grinder and cut the outside until you can pull the tip out. Its pretty hard to square the ends up without a lathe once you get the cut to length. I have chucked them in a valve grinder and used a file to square them. I built a fixture to press them together, its a thick wall piece of tubing welded to a flat plate, the inside diameter is about .060 bigger than the pushrod tube. The tube holds the tube square to the press and helps from bending the tube while pressing, put the tips in the freezer for a while, and I warm the tubes with a heat gun, put the ends in and a couple pumps on the press and its done. Make sure you look at the radius on the tip where it goes into the tube, you usually have to take a bigger drill bit and put a champfer on the inside diameter to get the tip to seat fully on the tube. I have been giving Manton a basic length and they send me the push rods with only one end pressed in, so I can finish them myself.
Re: Shortening pushrods....looking for advice 1st timer [Re: Cab_Burge] #2370722
09/14/17 01:55 PM
09/14/17 01:55 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Yes I called and asked its .150 they can be shortened not .015 my mistake.....So if I can get an end off/out this plans seems good. Any advice on getting an end out? As this seems to be the hard part....And yes to have shortened by Manton is only few dollars less than a new set.
(I was just thinking that it shouldn't be too hard to make a tool to carefully push the cup ends off the tubes if they are that tough)
Take care,
Rick
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370780
09/14/17 03:39 PM
09/14/17 03:39 PM
crlush Offline
crlush  Offline
Do you know anyone with a lathe, cut one to the length you want then add a stop and cut the rest.
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370790
09/14/17 04:09 PM
09/14/17 04:09 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I've shortened many sets of manton rods. You won't get the end out. The way shorten them is put them in the lathe. Grind a cut off tools thickness to the amount you want to shorten them. Run the cut off into the rod just under the insert. The insert is hard so when you hit it, no big deal. Usually harder than the tool you'll use. So you wind up with the thickness of your cutter removed from the length of the rod, and the insert bare in that spot. Then heat a little and press the insert deeper into the rod.
manton reams that press fit, and you'll keep your rod straight this way.
Re: Shortening pushrods....looking for advice 1st timer [Re: dthemi] #2370805
09/14/17 04:42 PM
09/14/17 04:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Thats a good way to do it. A clean square end and counterbore are key to the pushrod, and obviously not bending them trying to get an end out.
RIP Monte Smith
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370845
09/14/17 05:56 PM
09/14/17 05:56 PM
Nevada
merpar Offline
merpar  Offline
Nevada
If you make a cutter and part the .150 off you may be able to get the end out, maybe. But if you cut the .150 out don't press the end on in. The end has a slight radius where the shoulder is and the push rod tube will have a sharp edge. Therefore the end will not press flush to the end of the push rod. Also the bore may not be deep enough. I've been there and done that, but only on one push rod. Bought a new set. Maybe I'm too picky, just me.
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2370944
09/14/17 09:52 PM
09/14/17 09:52 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Thank you DT Hemi, guess I'm calling my old friend w a lathe in his garage....this way does sound easy, consistent, and reasonably fool proof.
Is there a preferred end to do this to? Or does it not matter?
Take care,
Rick
Re: Shortening pushrods....looking for advice 1st timer [Re: HemiRick] #2371033
09/15/17 12:34 AM
09/15/17 12:34 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I had a guy shorten my Manton's. He never took the end off, just lathed it carefully and then shoved the tip in the rest of the way.
Sheldon
