b body rear spring mount question
#2370540
09/14/17 05:01 AM
09/14/17 05:01 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
I know a 68 Plymouth b body is 1"shorter wheelbase than a 68 Dodge Is this gain in the rear spring mount length ? I would like to move my diff back a little to fit a 30"/30.5"tall rear tyre , I have a 68 Satellite . Or should I just use a 1/4"spacer/shim ? thanks ,
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
