Might hurt trans in union grove dragweek
#2370368
09/13/17 10:16 PM
09/13/17 10:16 PM
Posts: 667 IL
Dart451
IL
Think the converter is toast changing fluid on a false hope
Re: Might hurt trans in union grove
[Re: Dart451]
#2370436
09/14/17 12:03 AM
09/14/17 12:03 AM
Posts: 2,256 IL
furious70
IL
not rpm or speed related but anytime you give it gas?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Dart451]
#2370563
09/14/17 09:08 AM
09/14/17 09:08 AM
Posts: 2,256 IL
furious70
IL
I'm headed up there shortly, 312-533-9583 if you need parts
[Re: Dart451]
#2370712
09/14/17 01:47 PM
09/14/17 01:47 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
It is talking to you, listen and check very carefully Fix it before it gets worst or hurt someone in other words
[Re: Dart451]
#2371013
09/14/17 11:52 PM
09/14/17 11:52 PM
Posts: 2,256 IL
furious70
IL
they ran today with no issues. took it to a trans shop and found the pinion nut had lost preload, zipped that back up and it ran low 10's like it had been with no issue. It's a good lookin car!
[Re: Dart451]
#2371446
09/15/17 10:05 PM
09/15/17 10:05 PM
Posts: 2,256 IL
furious70
IL
and they won their first round in the elminator
[Re: Dart451]
#2371473
09/15/17 10:50 PM
09/15/17 10:50 PM
Posts: 2,256 IL
furious70
IL
somehow I missed 2nd round or they missed the call
Re: Might hurt trans in union grove dragweek
[Re: Dart451]
#2371842
09/16/17 07:54 PM
09/16/17 07:54 PM
Posts: 667 IL
Dart451
IL
We made the second round but think the we drove thru the converter. Car was way down on time and only went 10.87. Kim said it sounded good all the way down. That 8" converter towing a trailer 800+ miles was a champ and did all it could. I'm just amazed we made it thru dragweek with all the problems and even made it thru the first round of bracket race. Lot of lessons learned. Funny after all the chaos, Kim and I was unloading everything this morning and little depressed we not headed to another race track today. Dragweek! You don't understand it until you do it Will try and giving a better run down of events after I get caught up on projects and yard work. Thanks to everyone that stopped by and gave support!!
[Re: Dart451]
#2372263
09/17/17 04:27 PM
09/17/17 04:27 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Hey Jim, Congrats on the nice run and for finishing the event!!
You put in a ton of work to make it happen........ Glad to hear it as worth the effort.
