Re: 63 383, such a thing as an HP block then?
[Re: pushbutton]
#2370054
09/13/17 02:01 PM
09/13/17 02:01 PM
Posts: 43,523 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Cool, so it is probably a cop car motor out of a 64. It was in a barn when the guy moved in 15 years ago, so hard telling how long it has actually been sitting. The other numbers on the pad are 9 4 so it sounds like it was built on 9-4-63 for a 64 vehicle.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2370146
09/13/17 04:15 PM
09/13/17 04:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Had a 64 413 in my 300 that was stamped HP, there was also a non HP version
[Re: Bull1tt]
#2370542
09/14/17 05:07 AM
09/14/17 05:07 AM
Posts: 8,240 fredericksburg,va
cudaman1969
fredericksburg,va
I had a cop car that was V 38 HP. I have pics on other computer, 64 2dr sedan, police car VIN, 383 4bbl, 3spd stick on column. Came from VA state police auction I had one of theses cars from the Va state police just like above. First a police car black-unmarked, then a fire marshals car, then post masters car painted po blue. Big fishing pole on the roof and certified speedo. I put my max wedge in it for a race car in 1973
[Re: Rhinodart]
#2370574
09/14/17 09:58 AM
09/14/17 09:58 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Just picked up 6 engine from a friend who is moving and one has a casting date of 1963 with V 38 on the pad. It also has HP at the lower right of the pad punched lightly, is there such a thing as an HP 383 in 1963? I would say yes but at that time, the HP designation was used to distinguish a 4bbl assembly from a 2bbl assembly. It would not mean the same thing as 68-70.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#2370583
09/14/17 10:35 AM
09/14/17 10:35 AM
Supercuda
About to go away
About to go away
up yours
Just picked up 6 engine from a friend who is moving and one has a casting date of 1963 with V 38 on the pad. It also has HP at the lower right of the pad punched lightly, is there such a thing as an HP 383 in 1963? I would say yes but at that time, the HP designation was used to distinguish a 4bbl assembly from a 2bbl assembly. It would not mean the same thing as 68-70. How would it be different?
[Re: Supercuda]
#2370770
09/14/17 03:20 PM
09/14/17 03:20 PM
69CoronetRT
Harlan, Iowa
Just picked up 6 engine from a friend who is moving and one has a casting date of 1963 with V 38 on the pad. It also has HP at the lower right of the pad punched lightly, is there such a thing as an HP 383 in 1963? I would say yes but at that time, the HP designation was used to distinguish a 4bbl assembly from a 2bbl assembly. It would not mean the same thing as 68-70. How would it be different? Cam and valve springs would be different between a 2 and 4 bbl.
Seeking:
[Re: 6T4 Polara]
#2371645
09/16/17 11:03 AM
09/16/17 11:03 AM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
1964 Dodge street wedge engine stamped V42 HP. Wouldn't a V 41 be a 413? Yes
