Fired up after a long sleep. Sounded good, then... #2369623
09/12/17 08:10 PM
09/12/17 08:10 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
What's the prime culprit? Oil filter didn't fly off. Any most likely connection?
p.s. did not need this today...not that there's ever a good time.
Trying to enjoy life!
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369627
09/12/17 08:13 PM
09/12/17 08:13 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
oil * anti-freeze * trans fluid ? shruggy
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369634
09/12/17 08:18 PM
09/12/17 08:18 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looks like oil
hole in pan
Don't be the exception.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369647
09/12/17 08:32 PM
09/12/17 08:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Blew the oil filter gasket out?
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369654
09/12/17 08:41 PM
09/12/17 08:41 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Oil. Fired up, purred like a kitten for 60 seconds, then some secondary noise made me think "uh oh" then oil light on. I immediately shut it down and went around front and the car was bleeding out oil.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369741
09/12/17 11:14 PM
09/12/17 11:14 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Oil filter was super loose. Guess I should have checked before I fired it up. Hand-tightened, will fill up with oil and try again. Or should I get a wrench?
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369753
09/12/17 11:24 PM
09/12/17 11:24 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
hand tighten only.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369801
09/13/17 12:26 AM
09/13/17 12:26 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No wrench. You might want to spin on a new one.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369848
09/13/17 01:36 AM
09/13/17 01:36 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Did you check to see the gasket was still in place?
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369865
09/13/17 02:10 AM
09/13/17 02:10 AM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Thanks, ok I will get a new filter and hand tighten it, fill with oil, then fire it up again. Now I have to figure out how to get all that oil out of my engine compartment. yuck! do people still steam clean and is that advisable?
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369884
09/13/17 04:03 AM
09/13/17 04:03 AM
Go buy several cans of engine degreaser and use it several different times after rinsing off the first batch scope Not the foaming type either tsk : twocents
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369895
09/13/17 05:49 AM
09/13/17 05:49 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Go buy some Gunk at the auto parts store. Don't spray anything electrical with it.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369899
09/13/17 07:11 AM
09/13/17 07:11 AM
UP
finn Offline
finn  Offline
UP
Double gasket will do that.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2369903
09/13/17 08:12 AM
09/13/17 08:12 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Douse it with Simple Green and blast it at the do it yourself carwash.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370021
09/13/17 01:23 PM
09/13/17 01:23 PM
Cincinnati, Ohio
Cincinnati, Ohio
I change oil for a living...for 33 years now at the same company.
I used to think hand tight was good but from experience I found out that is not tight enough sometimes. So I spin them on hand tight and then they need a little torque n with a filter wrench to insure what happened to you does not not happen to a vehicle going down the road.
I always put some dirty oil on the rubber gasket before installation. Yea dirty oil whats dripping off the vehicle only because I am lazy and it works for many years now.
If I am doing big trucks with big filters then I fill the filter 3/4 full first with fresh oil and then it get a little fresh oil on the gasket.
Use a wrench!
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370039
09/13/17 01:46 PM
09/13/17 01:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Anyone bother to read the directions when putting on a new filter?
Wix:
Spin on the new filter. When the gasket contacts
the mounting base, rotate the filter 3/4 turn.
Fram:
Screw new filter on until gasket reaches base contact. Then tighten according to instructions on filter using tightening guide markers.
Cummins:
Carefully read the installation instructions printed on the outside of the filter to determine the number of turns the filter must to be rotated past gasket contact for proper installation and gasket compression.
Purolator:
Tighten the amount specified for your filter beyond gasket contact (3/4, ¾ - 1, etc)
They all also state use CLEAN oil and not grease.
Re: Fired up after a long sleep. Sounded good, then... [Re: Supercuda] #2370050
09/13/17 01:57 PM
09/13/17 01:57 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have ALWAYS filled the filter then used some of that oil on the gasket, spin it on quickly (some oil loss is normal) then tighten 3/4 turn to seat the gasket. Never just hand tighten or use double gaskets. tsk
JB Rhinehart, Realist
A-Body's RULE!
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370064
09/13/17 02:16 PM
09/13/17 02:16 PM
Never had a spin-on oil filter drip a drop when its been hand tightened.
Of course you have to be smarter than the filter and make sure it and your hands are clean so you can get a solid grip. (Did I really need to say that?)
Yes, the "standard" is film of new oil on the gasket and tighten 3/4 turn once the gasket makes contact. For a new filter.
Filter wrenches can distort and puncture the filter case.
Re: Fired up after a long sleep. Sounded good, then... [Re: calmopar] #2370065
09/13/17 02:21 PM
09/13/17 02:21 PM
Grand Prairie,Texas
Grand Prairie,Texas
Nothing worse than some yoyo that tightens the oil filter to the point you have to chisel it off to change oil.
Re: Fired up after a long sleep. Sounded good, then... [Re: nomore65BelvJim] #2370108
09/13/17 03:21 PM
09/13/17 03:21 PM
Cincinnati, Ohio
Cincinnati, Ohio
It don't sound like you have ever done a big truck oil change, it is impossible to get those big filters tight by hand. In 33 years of doing it here at work, I have yet to damage a filter big or small by using filter wrench on them.
