So basic, it's embarrassing! #2369717
09/12/17 10:54 PM
09/12/17 10:54 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
I'm mounting a remote filter adapter on the motor plate for my big block. I'm using a Milodon pump and cover set up for dual external pickup. I've never seen this brought up before. The pump cover isn't marked. Which line is pressure to the filter and which one is return? For simplicity, let's consider the pump fittings "High" mounted and "Low" mounted.
Re: So basic, it's embarrassing! [Re: sgcuda] #2369728
09/12/17 11:04 PM
09/12/17 11:04 PM
Kirkland, Washington
Pacnorthcuda Offline
Not sure if this answers your question, but oil ENTERS the filter through the holes circling the large center hole and oil EXITS the large center hole on its way to the engine.
Re: So basic, it's embarrassing! [Re: Pacnorthcuda] #2369757
09/12/17 11:28 PM
09/12/17 11:28 PM
sgcuda Offline OP
sgcuda  Offline OP
Thanks, but no, it doesn't answer my question. The filter adapter is marked. It's the pump cover that isn't. I think it's funny, over 50 views and it seems like nobody else knows either. Easy enough to figure out, though. Just might get a little messy.
Re: So basic, it's embarrassing! [Re: sgcuda] #2369765
09/12/17 11:34 PM
09/12/17 11:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep.. might get messy.. but pour some oil in
it and crank it over or use your priming tool
wave
Re: So basic, it's embarrassing! [Re: sgcuda] #2369767
09/12/17 11:35 PM
09/12/17 11:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nothing to be embarrassed about, who hasn't "screwed the pooch" a few times............ biggrin
Re: So basic, it's embarrassing! [Re: Pacnorthcuda] #2369770
09/12/17 11:39 PM
09/12/17 11:39 PM
n.c.
geo. Offline
geo.  Offline
n.c.
There are several manufacturers of these, without pics I wouldn't hazard a guess.
With the info above and some compressed air, you can blow thru the passages and figure it out. And then mark it permanently!
Re: So basic, it's embarrassing! [Re: sgcuda] #2369809
09/13/17 12:38 AM
09/13/17 12:38 AM
The front hole on top, closest to the heads, is the outlet and the bottom hole in the front of the adapter returns the oil into the block
Pull the pump out and look at it scope up
Re: So basic, it's embarrassing! [Re: sgcuda] #2369816
09/13/17 12:44 AM
09/13/17 12:44 AM
sgcuda Offline OP
sgcuda  Offline OP
Thanks, Cab. That's what I thought.
[image][/image]
Re: So basic, it's embarrassing! [Re: sgcuda] #2369817
09/13/17 12:45 AM
09/13/17 12:45 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If I remember tomorrow I'll look at mine , I think cab is right though.
Re: So basic, it's embarrassing! [Re: sgcuda] #2369820
09/13/17 12:48 AM
09/13/17 12:48 AM
sgcuda Offline OP
sgcuda  Offline OP
Thanks. You would think for that kind of money, the least they could do is identify the ports.
[image][/image]
Re: So basic, it's embarrassing! [Re: sgcuda] #2369835
09/13/17 01:22 AM
09/13/17 01:22 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That's $100 more.............. biggrin
Re: So basic, it's embarrassing! [Re: sgcuda] #2369857
09/13/17 01:59 AM
09/13/17 01:59 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
Just watch to see which one the squirrel goes into and which one he comes out of. grin
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: So basic, it's embarrassing! [Re: MadMopars] #2369909
09/13/17 08:40 AM
09/13/17 08:40 AM
sgcuda Offline OP
sgcuda  Offline OP
haha At least I'll finally be known for something on this site.
Re: So basic, it's embarrassing! [Re: sgcuda] #2369913
09/13/17 09:11 AM
09/13/17 09:11 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Note the arrows I put on mine when I ran that pump.
Re: So basic, it's embarrassing! [Re: sgcuda] #2370001
09/13/17 01:06 PM
09/13/17 01:06 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
They are correct. From the Milodon website:
TECH NOTE: On Milodon oil pump covers, the TOP port is "Out" while the Bottom port is "In".
2011 Drag Pak Challenger
Re: So basic, it's embarrassing! [Re: sgcuda] #2370389
09/13/17 10:40 PM
09/13/17 10:40 PM
sgcuda Offline OP
sgcuda  Offline OP
Thanks, guys. Couldn't find that info on Milodons site. A simple arrow engraved in the housing would be nice.
[image][/image]
Re: So basic, it's embarrassing! [Re: sgcuda] #2370451
09/14/17 12:20 AM
09/14/17 12:20 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, they are CNC machined and those arrows would take 2 seconds to put on there and it would make it a better product.
Re: So basic, it's embarrassing! [Re: rickseeman] #2370499
09/14/17 01:42 AM
09/14/17 01:42 AM
The new ones are CNC, the old ones where cast, which I have several of thumbs shruggy
Re: So basic, it's embarrassing! [Re: sgcuda] #2370620
09/14/17 11:57 AM
09/14/17 11:57 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
"So basic, it's embarrassing!"
So is removing ball joints on a Jeep! laugh2
Glad you got the answer thumbs
Re: So basic, it's embarrassing! [Re: roadhazard] #2370728
09/14/17 02:03 PM
09/14/17 02:03 PM
sg66mopar Offline
Happy Birthday sg66mopar  Offline
I stamped mine "IN" and "Out" with steel stamps, right on the front so it's easy to see.
