Re: Eddy RPM air gap/ crosswinds for SB
[Re: Dakota_Don]
#236980
02/26/09 02:54 PM
02/26/09 02:54 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
nope...got a air gap on my duster..
it idles a little rough due to the camshaft 231/237 @.050 duration.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Dakota_Don]
#236982
02/26/09 03:13 PM
02/26/09 03:13 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I have an airgap on my 417 stroker and it idles a little rough but that is becuase it has a MP 484 cam in it (241/241 duration, .484/.484 lift, with a 108 lsa. I think the rough idle is mostly due to the lsa becuase a 241/241 cam in a 417 stroker is not that big of a cam.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: loco340cuda]
#236983
02/26/09 06:36 PM
02/26/09 06:36 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
He's mistaken. Not sure who you called, but there are a couple who really profess to "know" a lot, and they are simply putting a huge emphasis on certain aspects of a build. You'd be hard pressed to get an Airgap to idle rough on a 318. The Crosswind has smaller ports, both in length and volume, and the casting quality stinks. So a rough idle can be from poor fitment, or porosity, or port mismatch. The one I tried seeped coolant out the rear corner of the casting, had poorly tapped holes, and was a very brittle aluminum when you did try and tap it... There are reasons they are half the money, and it's not a perfect copy as some suggest.
[Re: dogdays]
#236985
02/26/09 07:42 PM
02/26/09 07:42 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have an air gap on my 360, the magnum head version. It has a Summit K6901 cam witch is 218/228 duration at .050" lift and about .470" lift at the valve. I have a 4-speed and this thing idles "stock" smooth at 800 rpm. I'd also be lucky to have an 8.8:1 compression ratio.
The air gap works great. make sure your choke works properly. My car has a 600 holley electric choke.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: dogdays]
#236986
02/27/09 02:17 AM
02/27/09 02:17 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
Moper is right. Not an issue. One ironic thing about the idiotic "advice" is that the Perf RPM and the Air Gap have the same size runners. They are the same intake except the Air Gap heats the intake air less. This may be an issue on a cold start in cold climate but it isn't because of the runner size!
I would not recommend any Performance Products intakes.
R.
So the Performer RPM and the Air Gap are the some exact height? Are they the same manifolds, just the air gap is hollowed out underneath the plenum??????
[Re: Dragula]
#236991
02/27/09 11:39 AM
02/27/09 11:39 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
PHR says 477HP yet the dyno sheet says other wise What's up with the breather where the fuel pump used to go? That crank is pretty! Guess at their HP level they could have gone cast for less reciprocating weight?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
