Dana 70 DRW to SRW #2369773
09/12/17 11:42 PM
09/12/17 11:42 PM
Wisconsin USA
themoparmanjc Offline OP
Wisconsin USA
Anyone know what is needed to convert a dually dana 70 to single rear wheel? It's in a 1990 W350 Cummins. I am swapping the drivetrain into my 85 w350 and I don't want a dually. I already have the front axle figured out. I have hubs from a front dana 60 srw. I was doing some research and some guys say the dually axle is shorter. In that case could I just run a wheel spacer?
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
Re: Dana 70 DRW to SRW [Re: themoparmanjc] #2370485
09/14/17 01:17 AM
09/14/17 01:17 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Bolt pattern & stud size is larger on the dualie....
No idea on width.
Ed
Re: Dana 70 DRW to SRW [Re: Mr. Smurf] #2370498
09/14/17 01:41 AM
09/14/17 01:41 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
dually is narrower,and you may not have room to relocate the spring perches
my ladder of success is missing some rungs
Re: Dana 70 DRW to SRW [Re: themoparmanjc] #2370633
09/14/17 12:17 PM
09/14/17 12:17 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Depends on weather pickup dually or cab and chassis dually. More info on my lunch break but if cc axle just put single wheels on.
Angry white pureblood male
Re: Dana 70 DRW to SRW [Re: themoparmanjc] #2370735
09/14/17 02:14 PM
09/14/17 02:14 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Ok, back to it...
Spring perches are the same for all pickups. SRW axle is the narrowest of all three, cab and chassis DRW axle is about 3_4" wider, pickup DRW axle is about 3-4" wider than that.
Like I said if you have a cc axle, I've run them srw the rear tires come out and fill the wheel well, looks ok to me.
All 8 lug are 8*6.5 though dually do use 5/8" studs vs 1/2" for most srw.
Re: Dana 70 DRW to SRW [Re: themoparmanjc] #2370755
09/14/17 03:00 PM
09/14/17 03:00 PM
Wisconsin USA
Wisconsin USA
Thanks ruderunner
Re: Dana 70 DRW to SRW [Re: themoparmanjc] #2370955
09/14/17 10:11 PM
09/14/17 10:11 PM
ky.
K
kenworth_goose Offline
K
ky.
Dually rears are 2.5 inches wider per side. So 5 inch difference. Just find a set of single wheel hubs and use them. A cab and chassis rear end is the same width as the single wheel diffs if I remember right.
Re: Dana 70 DRW to SRW [Re: themoparmanjc] #2370996
09/14/17 11:13 PM
09/14/17 11:13 PM
Wisconsin USA
Wisconsin USA
I thought axle shafts are different lengths between srw and drw
Re: Dana 70 DRW to SRW [Re: themoparmanjc] #2371352
09/15/17 06:22 PM
09/15/17 06:22 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Need to know which dually axle you have.
Cc axle is wider than srw, just a couple inches though and nothing to fret about. Pickup dually is much wider than srw, the inner tires end up in the same place as srw tires.
Not sure about swapping hubs or shafts.
