Re: So basic, it's embarrassing!
[Re: Pacnorthcuda]
#2369757
09/12/17 11:28 PM
09/12/17 11:28 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Not sure if this answers your question, but oil ENTERS the filter through the holes circling the large center hole and oil EXITS the large center hole on its way to the engine. Thanks, but no, it doesn't answer my question. The filter adapter is marked. It's the pump cover that isn't. I think it's funny, over 50 views and it seems like nobody else knows either. Easy enough to figure out, though. Just might get a little messy.
[Re: Pacnorthcuda]
#2369770
09/12/17 11:39 PM
09/12/17 11:39 PM
Posts: 259 n.c.
geo.
n.c.
Not sure if this answers your question, but oil ENTERS the filter through the holes circling the large center hole and oil EXITS the large center hole on its way to the engine. There are several manufacturers of these, without pics I wouldn't hazard a guess. With the info above and some compressed air, you can blow thru the passages and figure it out. And then mark it permanently!
[Re: sgcuda]
#2369809
09/13/17 12:38 AM
09/13/17 12:38 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
The front hole on top, closest to the heads, is the outlet and the bottom hole in the front of the adapter returns the oil into the block Pull the pump out and look at it
[Re: sgcuda]
#2369817
09/13/17 12:45 AM
09/13/17 12:45 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
If I remember tomorrow I'll look at mine , I think cab is right though.
[Re: sgcuda]
#2370001
09/13/17 01:06 PM
09/13/17 01:06 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
They are correct. From the Milodon website:
TECH NOTE: On Milodon oil pump covers, the TOP port is "Out" while the Bottom port is "In".
2011 Drag Pak Challenger
[Re: sgcuda]
#2370451
09/14/17 12:20 AM
09/14/17 12:20 AM
rickseeman
Stuttgart, Arkansas
Thanks, guys. Couldn't find that info on Milodons site. A simple arrow engraved in the housing would be nice. Yes, they are CNC machined and those arrows would take 2 seconds to put on there and it would make it a better product.
[Re: rickseeman]
#2370499
09/14/17 01:42 AM
09/14/17 01:42 AM
Cab_Burge
Thanks, guys. Couldn't find that info on Milodons site. A simple arrow engraved in the housing would be nice. Yes, they are CNC machined and those arrows would take 2 seconds to put on there and it would make it a better product. The new ones are CNC, the old ones where cast, which I have several of
